Prothy's 1977 Toyota Celica TA23 ST
sheepers
  • Replies 159
  • sheepers
    160
modified a fan shroud to fit. it didn't have one before and proper TA23 fan shrouds are pretty hard to come by so i made this one fit.
then i sand blasted it and I'm in the process of painting it right now, just waiting for the primer to flash off.
the other thing is that the fan sits a long away from the radiator and i wasn't happy with that so i made some spacers to move the fan forward about 30mm. now it will sit inside the shroud and actually do something. i should also paint the fan black i suppose.
25755001172_81e9c78f90_h.jpg2016-03-18_07-08-02 by sheepers, on Flickr
25755002852_004b38d7e9_h.jpg2016-03-18_07-08-11 by sheepers, on Flickr
25575222150_a132ce92c8_h.jpg2016-03-18_07-08-41 by sheepers, on Flickr
25798166951_6718664c03_h.jpg2016-03-19_12-57-34 by sheepers, on Flickr
25893644235_39b7c7a886_h.jpg2016-03-19_01-35-53 by sheepers, on Flickr
25894255005_32910f6ab9_h.jpg2016-03-19_02-21-48 by sheepers, on Flickr
been doing lots of little bits and pieces.
finished painting the last of the engine bay bits. these bits are the oil filler cap, the support bracket between the intake and the cam cover and the radiator over flow bottle. so now those bits are on the car and the overflow is plumbed up. the only thing left to do in the engine bay is plug in the windscreen washer pump and run a hose for the windscreen washers. I'm pretty sure thats all?
I've started on the dash resurrection now. all the plastic dash bits had been painted with some crap paint so I've had to very carefully bead blast them all and give them a coat of VHT plastic dye. they've come up looking really good but one of the parts that always cracks on celicas had cracked and someone had tried to fix it but  they made the plastic deform around the break so now I've glued it back together but it looks shit.
what else? the dash pad ill be putting in this car will be the one out of the V8. it was re-covered in auz about 15 years ago and it looks fine but I'm getting a dash fully redone at dashboard restorations and ill put that into the V8 and use the V8 dash in this car. all the hearer box is back in and I've put new foam seals on all the joints. 'oh, and I've got new inner and outer belt line seals for this car and they just turned up today so i can put them on as well.
oh and also I've  found someone in auz with an original pair of seat belts that they are willing to sell so they are on their way too.
26192770692_60cf17e732_h.jpg2016-04-07_06-51-00 by sheepers, on Flickr
26218959421_ba0a8d6e76_h.jpg2016-04-07_06-51-46 by sheepers, on Flickr
25680422524_fcbfcaf17d_h.jpg2016-04-07_06-52-02 by sheepers, on Flickr
26259361636_02729b7f0e_h.jpg2016-04-07_07-00-13 by sheepers, on Flickr
  • Like 9
got a bit done over the weekend.
friday night Nick came over and we finished up the wiring that was left to do and tidied it all up so thats finished now. the relays you can see in the pic will tuck up behind the plastic panel kick panel.
i put the dash back in the car, I've run out of paint so I still have the glove box lid and the centre bit to put back in. all the gauges and lights work which is a bonus.
today i set about mounting the drivers seat properly. the drivers seat is mounted further back than the passengers seat because id already modified the rails when this seat was in the blue car and it seemed stupid to put it in the car so only short people could drive it.
so the front bolts into the factory mounting places but the rear needed doubler plates as per the LVVTA standard. as it happens Clint needed something machined so he came over and had a look at what i was doing and gave it the OK so thats good.
what i did was weld the doubler plate to the seat rail with gussets so that the plate could sit on a nice flat part of the floor. the bolt comes up from the bottom with the other plate under the floor to secure it  as per the standard. the pictures are a bit pants but you should be able to see how its done.
25736555483_742b9cca97_h.jpg2016-04-10_04-55-24 by sheepers, on Flickr
26246924952_86514facf2_h.jpg2016-04-10_04-55-16 by sheepers, on Flickr
26339339055_085ba799e9_h.jpg2016-04-10_04-55-06 by sheepers, on Flickr
25734453754_833d59979c_h.jpg2016-04-10_04-54-57 by sheepers, on Flickr
did a bit more tonight.
mostly cleaning and painting trim pieces. the dash is all finished as is the center console and the kick panels. should finish the trim bits tomorrow.
in my search for a heater duct (which i didn't find) i found this,
26092532720_a04a58be66_h.jpg2016-04-11_08-59-07 by sheepers, on Flickr
so no idea why i have this. i know where it came from, it was in the mass of parts that came with my RA28 when i bought it. I've always assumed it was 18RG because there were some RG parts in amongst the things but nothing 2T so it pretty weird that it was there.
anywho, its internals are in better nick than the one on the car and its got a single diaphragm vacuum advance module which should work better and eliminate some stupid emissions crap. ill chuck it on and see how it goes.
today i put the door seals on and took the brakes apart so i can match some seals up for them at Stirling Clutch and Brake.
i also took the dizzy out so i could give the other one a try but it turned out that the one i found needs an external module that i don't have so i put the original one back in.
and it wouldn't go. no spark at all. fucked around with it to no avail so I've given up for now. bastard of a thing.
if i wanted a car that randomly decided to stop working all on its own id have bought a fucking british piece of crap.
fuck.
this is the ignition module that lives inside the dizzy. ordinarily its not in two pieces but my one is. its fucked which is the cause of the non existent spark.
25897135303_8678bd5b22_h.jpg2016-04-18_09-24-00 by sheepers, on Flickr
it goes without saying that the module is impossible to replace so Nick the sparky bought over some other bis and pieces to see if we could get the car to go again. we put a system together using parts he had but it only worked sometimes so Nick is going to test them properly tomorrow so we know which bit (the pickup or the module) is fucked and then go about trying to find new ones. hopefully then it will go properly.
26499969555_71feeaa44e_h.jpg2016-04-18_09-24-09 by sheepers, on Flickr
on to other things.
brakes, i have them. i got all the parts i needed from Sterling so i was able to put new seals and hoses in the front and new slaves in the rear.
its been a very long time since I've had anything to do with stock celica brakes and man are they shit. they have a stupid slider setup that wasn't a good idea when they were new, let alone 40 years later.
BUT - the good thing about celica struts is that the brake bracket bolts on with 4 bolts (rather that the caliper mount being part of the casting) so its pretty easy to make brackets to suit pretty much anything you want to fit.
26429962351_15142ce87b_h.jpg2016-04-18_04-08-52 by sheepers, on Flickr
other things that happened - the windscreen washers work now, ummm thats about it.
if we can get the thing to run I'm going to try and take it for a warrant this week.
26225547550_1431821df6_h.jpg2016-04-18_07-15-18 by sheepers, on Flickr
26406092572_250653404d_h.jpg2016-04-18_07-15-26 by sheepers, on Flickr
26472495176_29067dd90e_h.jpg2016-04-18_07-15-04 by sheepers, on Flickr
  • Like 8
