dave123456789 Posted October 13, 2014 Share Posted October 13, 2014 Hey guys I need a little help modifying a set of extractors to clear starter motor. The pipes on the right hand side need to be moved a little to the left and the two end pipes need to be on a bit more of a slight angle. Anyone up for it? Ill obviously pay for your help. Will need to bring a welder and shit, I'm in pakuranga. Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 13, 2014 Share Posted October 13, 2014 If that rear collector was cut out and a new one welded in higher up pointing down more would that help? Other option would to get one of those road runner starter motors. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 13, 2014 Author Share Posted October 13, 2014 Here's another picture, it's hitting on the underside of the last two pretty much directly above the collector. Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 13, 2014 Share Posted October 13, 2014 Befor they get cut up would Coby have another set witch would sute this motor? Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 13, 2014 Author Share Posted October 13, 2014 I have emailed Coby about this and will see what they say. These are the set to suit this motor, jig they used must be a bit off. I am also searching for a smaller starter to make things easier Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 13, 2014 Author Share Posted October 13, 2014 These are Coby extractors purchased from Coby so hopefully they come to the party. Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 13, 2014 Share Posted October 13, 2014 I reckon try an exchange set from COBY before you do anything. if all else fails I have a couple sets of headers witch could be cut up and I could bring my gas set. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 13, 2014 Author Share Posted October 13, 2014 Cheers mate, Ill keep you posted to see what happens. Damn this car is starting to annoy me, Please just go together properly so I can drive around in the summer I got heaps of cash to throw at this car so ill reward you nicely if you do indeed come give me a hand. Getting sick of sitting it it pretending to drive. 1 Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 15, 2014 Author Share Posted October 15, 2014 Coby is sending me a slightly different version of the manifold used in the Vauxhall Victor so will see if that makes any difference. Apparently moves the collectors further away which should clear engine and the first and last pipe don't come out so parallel so should fit. Hoping it turns up over the next couple of days and It fits. Excellent service from Coby, ill have both to test and I just send the least fitting back. 2 Quote Link to comment Share on other sites More sharing options...
