Jimjam Posted December 6, 2013 Share Posted December 6, 2013 Does anyone know how this window comes out? The two screws at the back end of the car are easy but I'm not sure how to remove it at the drivers door end. There's hinges I can see but they look as though there welded in place? Any ideas? Does the glass slide out maybe? Cheers. Quote Link to comment Share on other sites More sharing options...
Muncie Posted December 6, 2013 Share Posted December 6, 2013 Pretty sure you flick off 2 covers on inside of car exposing 2x 10mm or 12mm nuts that are bonded to the glass and you can lift the windows out have done this before on a ae 92 was ages ago. hope this is of some use to you. Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted December 6, 2013 Share Posted December 6, 2013 second this, pull the boot trimming out, pillar trimming ect, its all bolted in, you may need tube sockets as I think they are quite deep from memory : ) Quote Link to comment Share on other sites More sharing options...
