Brennan Posted October 28, 2012 Share Posted October 28, 2012 Noticed my tachometer is not hooked up to the new loom on the altezza 3sge/link g4. Would it be possible to hook this up? Don't really fancy having a gauge that doesn't work. Where would it go to now that there is no distributor? Quote Link to comment Share on other sites More sharing options...
Gomaxgo Posted October 28, 2012 Share Posted October 28, 2012 you can use one of the links outputs as a tacho signal, i did this in my starlet and works fine. Quote Link to comment Share on other sites More sharing options...
Brennan Posted October 28, 2012 Author Share Posted October 28, 2012 Sweet, cheers. i thought there must have been a way, wonder why he left it undone. Quote Link to comment Share on other sites More sharing options...
kpr Posted October 28, 2012 Share Posted October 28, 2012 probably wont work directly off the link. if it used to be driven off coil - . changing a resistor in the tach will usually make it work. or there is some other options, depending on what ignition you're running Quote Link to comment Share on other sites More sharing options...
