dave123456789 Posted October 25, 2012 Share Posted October 25, 2012 hey guys just wondering what i should gap them to? my workshop manual states .025in. (.63mm.) but that is with the old points system. Should I crank it open to .035? Or leave it as stock? thanks. might be a obvious answer but just thought i would ask. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 25, 2012 Share Posted October 25, 2012 What type of car? I've run all my OS cars at 0.8mm or my stuff thats newer than the 90's at 1.1mm and never had a problem. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 25, 2012 Author Share Posted October 25, 2012 65 super minx. ngk bp5es plugs Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 25, 2012 Share Posted October 25, 2012 Sweet as - go 0.8mm Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 25, 2012 Author Share Posted October 25, 2012 chur. will see how that goes. got morning off to trying to get weekend maintenance out of the way so i can actually use the car. thanks again. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 25, 2012 Author Share Posted October 25, 2012 Gapped them all at .032ish and car runs beautifully. idles smoother, drives smoother and no more gay jerkyness when you get back onto the gas after a gear change. now i can focus on driving it while saving for my weber rebuild. cheers. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 25, 2012 Share Posted October 25, 2012 Good result! Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 25, 2012 Author Share Posted October 25, 2012 just thought i would ask this here, my manual states idle should be at 500-550??? i currently have it at 1000 as it seems to be the smoothest as at 800 it rocks the car a little and any lower car runs like a bag of shit. what would cause this? just 45+ year old engine i guess? everything ignition related has been replaced/upgraded. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 25, 2012 Share Posted October 25, 2012 It should idle 750 - 800. Would most probably benefit with a tickle up in the carb mixtures and playing with the timing TBH Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 25, 2012 Author Share Posted October 25, 2012 my carb only has two points of adjustment, just the throttle stop to adjust the idle and the volume control screw. i'll check the timing saturday night and report back. got work too soon to be getting oil and shit everywhere. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 25, 2012 Share Posted October 25, 2012 The volume control srew is the mixture. I always set them by winding it in till it stumbles or stalls then wind it out and the engine should start to run smoother - keep winding it out till it just starts to stumble again and then wind it back in half a turn. After that adjust the idle to 750rpm if you can. Then reset the mixture as above. Keep trying until you are idling at 750 or cannot get the idle any lower. Boom mixture set.. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 25, 2012 Author Share Posted October 25, 2012 thanks heaps for your help this morning. i'll get straight onto it when i get free time next. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 25, 2012 Share Posted October 25, 2012 winkface - all good man - its part of the OS experience Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted October 30, 2012 Author Share Posted October 30, 2012 The volume control srew is the mixture. I always set them by winding it in till it stumbles or stalls then wind it out and the engine should start to run smoother - keep winding it out till it just starts to stumble again and then wind it back in half a turn. After that adjust the idle to 750rpm if you can. Then reset the mixture as above. Keep trying until you are idling at 750 or cannot get the idle any lower. Boom mixture set.. hey mate i tried tuning the carb and the car will die if i turn mixture screw in quite a bit but it will only die/stumble if i crank it so far out if falls out then the car dies. what would cause this? i also couldnt get it to idle at 750-800 so its still at about 900-1000 depending on how it wants to behave. i also have the lame problem of it dying when i come to a stop sometimes, i tried cranking the idle up to something stupid to see if that would fix it but even with a 1700rpm idle it would still die when slowing to a stop. i also had a crack at checking the timing with a bulb. i solder some wire to a bulb and set the pulling between the first at second notch (which it states in the manual to be between 5 and 10 degrees) but i had no idea where to hook the bulb up and a couple of fail spots i tried just kept it lit the whole time. i understand one goes to earth but where does the positive go?? edit: sorry if these seem like stupid questions, hate having a wof/reg car that you hardly drive cause it drives like shit. Quote Link to comment Share on other sites More sharing options...
