Yowzer Posted October 19, 2012 Share Posted October 19, 2012 So my Hillman Avenger is running CD150 twin carbs. One of which has decided to piss fuel out of the funny little air valve piston lifting pin thing. How do I stop this happening? Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted October 19, 2012 Share Posted October 19, 2012 Rebuild it? Most likely it's running rich and the float has become a sink.. Check diaphragm also for splits and needle valve for dirt or wear marks. Only adjust the needle with the correct tool which holds the piston in place or risk diaphragm splits Easy to make one out of a piece of steel fuel pipe and a allen key. Just google the original tool for specs Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 19, 2012 Author Share Posted October 19, 2012 I think I fixed it. Gave the float level a tweak and it stopped pissing out fuel. But then it ran out of fuel, so I tweaked the level up a bit. So it might now be all good. In any case the fuel isn't pissing out errrwhere Quote Link to comment Share on other sites More sharing options...
