Guest logan360 Posted April 4, 2013 Share Posted April 4, 2013 Right. I'm starting my 3rd build thread on 3 forums. Quote Link to comment Share on other sites More sharing options...
Guest durty Posted April 4, 2013 Share Posted April 4, 2013 Please do. Would make it 3 x 360s Quote Link to comment Share on other sites More sharing options...
Guest Slacker_Sam. Posted April 4, 2013 Share Posted April 4, 2013 Do it! Quote Link to comment Share on other sites More sharing options...
Guest logan360 Posted April 4, 2013 Share Posted April 4, 2013 Done burgers. not very comprehensive though but has a few photo's. and you will see my sunroof vent open in one. yes it does still work Quote Link to comment Share on other sites More sharing options...
Guest durty Posted April 4, 2013 Share Posted April 4, 2013 Jealous, mine is siliconed shut, have been tempted to pull the mechanism on mine apart and see if I can get it working again. Guessing it leaked a bit though if they felt the need to cover it in silicone Quote Link to comment Share on other sites More sharing options...
Guest logan360 Posted April 4, 2013 Share Posted April 4, 2013 Yea mine leaks if fully flush sitting so its up 2mm and no leaky no more! Quote Link to comment Share on other sites More sharing options...
Guest CaMpylobacter Posted April 4, 2013 Share Posted April 4, 2013 do they have drains? citroen/pug/bmw ones always block their drains up, tis usually an easy fix. Quote Link to comment Share on other sites More sharing options...
Guest logan360 Posted April 4, 2013 Share Posted April 4, 2013 Yea 4 drains but even if clear like mine, the seal fails over time and water builds up on the assembly it self especially if parked on flat surface. Quote Link to comment Share on other sites More sharing options...
Guest Slacker_Sam. Posted April 5, 2013 Share Posted April 5, 2013 Mine works and doesn't leak.... How do you like them apples Quote Link to comment Share on other sites More sharing options...
Guest logan360 Posted April 5, 2013 Share Posted April 5, 2013 ......... na your wrong. its broken. go away (T_T) lol Quote Link to comment Share on other sites More sharing options...
Guest Slacker_Sam. Posted April 5, 2013 Share Posted April 5, 2013 Hahaha Quote Link to comment Share on other sites More sharing options...
Guest durty Posted April 5, 2013 Share Posted April 5, 2013 Install some low sam Quote Link to comment Share on other sites More sharing options...
Guest Slacker_Sam. Posted April 5, 2013 Share Posted April 5, 2013 Well thats the plan but 1st I need to wear out my big tyres and install tiny tyres. Then install low. Quote Link to comment Share on other sites More sharing options...
Guest logan360 Posted April 5, 2013 Share Posted April 5, 2013 I need to install some negative height adjustment too. but if i keep my 16's i can't lower front only back. front already seems lower than my other 360's though. Quote Link to comment Share on other sites More sharing options...
Guest durty Posted April 5, 2013 Share Posted April 5, 2013 Yeah. The front is a pain. Mine is lowered about as far as it can go. Has an inch of travel with 13s with tiny tyres. To go lower would need major inner guard modification Quote Link to comment Share on other sites More sharing options...
Guest logan360 Posted April 5, 2013 Share Posted April 5, 2013 To keep my 16's i need spacers which my mate is making as the wheel hits the strut, need my guards rolled and some narrower rubber to stretch, all so my 16's fit properly. Quote Link to comment Share on other sites More sharing options...
