1Gesus's Levin/Trueno/Supra..
1Gesus
Had another look at running the 1ggze cas with 1gge water outlet after seeing d.p.n.s do it. And also because i got this thermostat housing. Credit to mjrstar
But making it all fit is another story. For all the material i had to take off left a hole in the housing, and its still pretty tight
So now im on the hunt for another 1gge thermostat housing. Because I want my engine bay looking like this:
Maybe you fellas mentioned at the start of the post can enlighten me on the finer details to making this fit without making a hole
In other news, made up some turbo water lines. I'll put a sleeve on the on the goes down in between the manifold. But this meant my turbo oil feed hard line no longer fitted.
  • 7 months later...
So the ol 1g is running! Still a few issues to sort out. Mainly the ignition timing apparently changing when I turn it off then try to start again... I can't understand how it could though. Freaks me out. Anyway, here's a quick vid, shes a quiet thing and that's with only a dump pipe
