SOHC Posted July 19, 2012 Posted July 19, 2012 Hello I have a 4 speed zephyr zodiac gearbox I need to shorten the input shaft as I am fitting it to an earlier ford motor, I have unbolted the front bearing retainer, my question is if now I slide the input shaft out will the syncro fall apart and drop down inside the box? Quote
SOHC Posted July 23, 2012 Author Posted July 23, 2012 Dose anyone know where i could find a book on line? Quote
otazup Posted August 3, 2012 Posted August 3, 2012 hey bro ive got info regarding these beauty gearboxes do you still need the help Quote
SOHC Posted August 3, 2012 Author Posted August 3, 2012 I got it sorted, didn't need to shorten the shaft in the end, it was bang on the right size, what kind of info do you have? I got a cople of zephyr boxes, I was going to rebuild one anyway Quote
otazup Posted August 3, 2012 Posted August 3, 2012 sweet as , ive got a workshop pdf somewhere for mkivs which i could email to you. pretty sure it shows the gearbox exploded view and shifter setup etc. cheers jason Quote
SOHC Posted August 3, 2012 Author Posted August 3, 2012 sweet as , ive got a workshop pdf somewhere for mkivs which i could email to you. pretty sure it shows the gearbox exploded view and shifter setup etc. cheers jason That could be realy cool, thank you Quote
otazup Posted August 3, 2012 Posted August 3, 2012 sweet i found it, if you want to forward an email ill send it to you Quote
Cortina1967 Posted May 30, 2024 Posted May 30, 2024 What other yolks can i use for a mk4 zodiac box c4s fit? Heard they do? Quote
