J-W-G Posted May 16, 2012 Share Posted May 16, 2012 Looking at a B1600 diff from a 76. From what ive heard the courier/B2000/B2600 lsd centres fit. What work is required to fit it? Shimming? Any aftermarket options? Cheers Quote Link to comment Share on other sites More sharing options...
shizzl Posted May 16, 2012 Share Posted May 16, 2012 xlt courier....i have one here....good diffs Quote Link to comment Share on other sites More sharing options...
J-W-G Posted May 16, 2012 Author Share Posted May 16, 2012 Ive just heard that they have shit ratios? Ideally i want a 3.7/3.9 or close to Quote Link to comment Share on other sites More sharing options...
Jase Posted May 16, 2012 Share Posted May 16, 2012 mazda mpv gets a 3.9 or 3.7 with non lsd, in a 76 housing the later head will fit but one axle (original axles) needs a bit of spline trimmed down for it to come together, dana lsd's fit the axles but i've yet to find a carrier that will take them without modification although they are very close ie same bearings etc etc just the offset is too far out without trimming the gears down from the older diffs Quote Link to comment Share on other sites More sharing options...
shizzl Posted May 17, 2012 Share Posted May 17, 2012 fucking easy to change the ratio on the lsd heads though...i have some various ratio diffs for the stockcar,had a 3.8,3.9,4.1,4.4,4.7...all mazda/ford... most are 4.1... Quote Link to comment Share on other sites More sharing options...
J-W-G Posted May 17, 2012 Author Share Posted May 17, 2012 Alright. Ive just bought a 76 diff that 1370mm so will fit the escort. Ive heard also that 84/85 rx7 lsd's will fit and maybe the torsen from an mx 5/miata? Quote Link to comment Share on other sites More sharing options...
shizzl Posted May 17, 2012 Share Posted May 17, 2012 yup the series rx7 will... Quote Link to comment Share on other sites More sharing options...
J-W-G Posted May 17, 2012 Author Share Posted May 17, 2012 yup the series rx7 will... Series 2 or 3 i take it shizzl? Anyone know of the miata torsen lsd fitting? Quote Link to comment Share on other sites More sharing options...
J-W-G Posted May 17, 2012 Author Share Posted May 17, 2012 Done some research and s3 rx7 and mx 5 torsen fit but are 7inch wheras b1600 is 8inch? Quote Link to comment Share on other sites More sharing options...
shizzl Posted May 17, 2012 Share Posted May 17, 2012 im totally missing out words and shit tonight. series 3...from what ive found out is you use the s3 guts but still use the b16 crown wheel and pinion.. so still leaves you with a shitty ratio. Quote Link to comment Share on other sites More sharing options...
J-W-G Posted May 17, 2012 Author Share Posted May 17, 2012 Ah alright. May aswel fit the courier lsd with a 3.7/3.9 ratio? If I get a rx7 or mx5 torsen ill do a write up or the process after i get it in Quote Link to comment Share on other sites More sharing options...
J-W-G Posted September 4, 2012 Author Share Posted September 4, 2012 Have found a B2600 diesel 4.1 LSD! Now from what ive read as my B1600 diff is 1974 model it needs an axle shortend and one lengthend for the LSD to work? Can anyone elaborate? Quote Link to comment Share on other sites More sharing options...
