rb drifters' 1974 toyota ms65 crown
scored this off my mate for a sweet deal as buyer on trademe never contacted him.
discussion thread viewtopic.php?f=18&t=32921
put the 15x8 steels on it again to keep it looking sweet
motor heaps up real quick so will try fix that asap.
also carby is fucked on the 202
is too low for next wof so will be geting legit springs for wof man
got quoted $800 to make new rear gaurds/quarters as these ones are really rotten. so will be saving up for that.
rest of rust and panelbeating i will get my mates old man to do and try a hand at it myself.
also will be remaking exhaust to make it sit higher off the ground as it sits 30mm off road atm
will be geting a full repaint once panels are all sorted, so should be a sweet car once paint and new motor is in it
started attacking the rust around rear window, wish i hadnt now.
was more than expected, gunna get the whole panel re made by same dude thats doing the rear quarters as its way out of my skills to fix.
rear gaurds....
door for it.
and other rust i will be able to do myself, hopefully.....
just beacuse.....
todays progress, started sanding/bogging drivers door. still needs top coat of bogg and smoothing off
removed the cut springs and replaced with standard sigma wagon rear springs, fitted perfectly!!
also found that it was diff oil leaking onto the left rear brakes not brake fluid. so now time to investigate even more.
got back from rust repairs still requires filler work,
sunroof goneburgers.......
along rear window, new panel was made
rear quarters
also have been asked to drive a few of the bros that run oversteer tv/spbnz to the d1nz awards in this so ive got about 2 months to get this ready, well runing right and legit atleast, might end up matty b until i afford a decent paint job
got up this morning and decided to get shit done
so first up was getting the new motor/box
another 202, black block with 350 holley 2 barrel carb, extrators and yelow terra head. with trimatic box soposivly all in good runing condition.
then got the nutech out and started filling in were sunroof panel was welded in, and run out of nutech so that was as far as i got
crapy ipod pics cause forgot my camera
  • 5 months later...
crown is in new hands!
after a long time of envying this car + convincing rb drifter to sell it i finally had enuf funds to buy this fine automobile
shit will be getting down the worked 202 is on the engine stand getting the old clean up then need pull the old 202 out and slap that in its place
the diff seal is leaking so much fluid on the left rear plus now breaks are poked and locked on ... is any one sure what diff it has papers say hq people say torrana can any one help out ?
cheers josh
pic's just because
so this week ive been getting stuck into this crown. so be prepared for mass load of pics ..
got the old girl into the shed on Monday morning
i decided to see what the problem was with the rear brakes ....
i removed to left rear wheel and remove the brake drum to find all diff oil through out the brakes well there poked then decide to pull the axel to see what i issue was ... well there wasnt much of the wheel bearing left by the time i got there steel through out the houseing :/
so i removed both axels and diff head to to give it a good clean out.
man the lenghts people got through to make shit work this thing has 2 different axels one believed to be a hr 5x114 and another 5x120 hq that has been redrilled both are different splines and some one has changed the diff head to suit.
hq axle
hr axle
after i cleaned all the crap out of the housing i niped into town grabed a wheel bearing
also decovered that the rear window dosent fit..... the rear panel that has been made dose not accomadate for the chrome plus isnot the correct shape
will have to be reshaped and timed back to that line..
oh wheel specs
14x8 5x114 falcons centres have been welded into roh wheel bands then chromed
175/65r14 supercats
ill upload more when i get home from work chuur my beos!
next up is to get the rear springs to a legal form. so i put the sigma rear springs in to replace the cuts and achieve sky high muscle car stance.
cuts vs sigma!
sweet sky high ballin.
after i done this i started removing engine parts this lead to me and a mate getting a little out of hand..
check out the wiring .... its a fucken nightmare! i might leave that to the pros so many wires that lead to no were
removing the final few bolts
and out she comes
now i have to remove the sump off the old 202 to install on the worked 202
also a few of my ordered parts came
new brake shoes and cyclinders
and some diff oils
over the next few days ill tidy up the engine bay and give it a repaint along with the new 202
also any one know if there are bosskits out there to suit crowns i realy wanna slap my nardi on this old girl
all feedback would be choice.
ok so long time no update!
well to say my self i have been usless and sweet f all has been done of the last month!
well diff brakes are all complete now ( i now hate drum brake springs!)
have been playing around with the front end getting rid of the layer's and layer's of old lacker paint which just melts and smudges every were
so the other day i got the boys round and we got stuck in cheers to Da BAF harry and dave!
the inner gaurds and the firewall and chassis will be painted gloss black at this stage the fire wall is coated in a product call brunox which is a expoxy primer and rust killer
the front end pieces are now ready for primer/hammer/bog work then will be painted in druopox black primer until later down the track!
oh and the 202 has been painted!
ok big update coming your way! chuuur
well got the engine bay painted
came up prity lush cheers to the old man
then the oldschool boes came round on saturday night to try get the 202 back in the the hole
resulting in a kunty tourque converter and a cracked bellhousing
so swaped the bellhousing of the old 202 its far thicker and stronger
motor all in the the hole bolted in started bolting shit up like fuel pump thumostat housing ect
i installed the headers only to find they bind with the steering so will have to tweak them slightly
done some more sanding
and rust work
that is all
