Avenga Posted March 8, 2012 Share Posted March 8, 2012 Hi guys. I am currently trying to replace the rear window rubbers on my Hillman Avenger. I am unable to find any rubbers for the Avenger but a few places have told me that Mk2 escort rubber will fit. I was hoping someone with a Mk2 escort could measure their rear window and let me know the dimensions. Also a photo of the general shape of the window would be great. Cheers Quote Link to comment Share on other sites More sharing options...
BDA780 Posted March 11, 2012 Share Posted March 11, 2012 I think we have some old mk2 rubbers at work. Ill have a look. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted March 11, 2012 Share Posted March 11, 2012 just gave mine a quick messure up bit hard with lovers on its a 79 mk2 esky messurments were taken from inside edge of rubber to other inside edge rubber is 25mm wide with trim strips in top width 1100mm bottom width 1220mm side height 590mm middle height 600mm so if ya add 25mm per side of 50mm to each size you get the outside edge of the rubber hopfully that helps Quote Link to comment Share on other sites More sharing options...
Avenga Posted March 11, 2012 Author Share Posted March 11, 2012 Awesome! Thanks heaps. You can't buy Avenger window rubbers anymore and I am trying to fine something that will fit. I will compare that to the Avenger glass and see if it is close. Cheers Quote Link to comment Share on other sites More sharing options...
