77magnum13hundy Posted January 10, 2012 Share Posted January 10, 2012 HI I have 4 wires comming out of my dizzy, red, green, yellowish and white. The white wire has got 2 additional wires joined to it also white. Does anyone know where they would go? its a 24 tooth model with a 1 tooth actuator on the top passing thru two magnets on oposing sides Im thinking white is a common negative wire, making it Ne on the ecu pinout, for engine speed signal? RPMs? G- is the red or not? leaving green and yellow.... to be G1 or go to the ignitor, any help would be appeciated. I guess try it one way, if no spark then try the other. Cheers ECU and dizzy off a smallport redtop ae82 model running map sensor. Quote Link to comment Share on other sites More sharing options...
kpr Posted January 10, 2012 Share Posted January 10, 2012 they all go back to the ecu. white wires are definitely the grounds, (G) for all 3 sensors. NE is the 24 tooth wheel, g1 & g2 are the other 2. take the cap, rotor and bit that says do not remove off, and you can see what wire goes to which sensor. Quote Link to comment Share on other sites More sharing options...
