HighLUX Posted October 19, 2011 Share Posted October 19, 2011 As above the gearshift cables in the Townace are shloppy and seems quite stiff to shift gears making 3rd and 5th quite hard to find sometimes. Can they be adjusted at the gearbox? and could I spray something down inside the cable to lube them up, CRC silicone spray etc? Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted October 20, 2011 Share Posted October 20, 2011 depends were the sloppy bit is if its the bush's were it joins to the leaver or box you can knock them out and put roller-blade wheel bearings in to make it super tight with out seeing it i donno if thats the type of set up it has or not Quote Link to comment Share on other sites More sharing options...
