crooked Posted September 21, 2011 Share Posted September 21, 2011 Discussion - viewtopic.php?f=18&t=29364 Brought this off Trade Me the other day, Runs good, needs a new battery... abit of panel work where the old owner tried to smooth things off etc etc... Came with heaps of old stuff, manuals, rego slips etc etc , was cool to read through and see where it came from. Plans so far are just to tidy it up and get it all one color, probably go with the red wheels and white walls look for now, iv got some bullet shaped center caps, find a visor and some roof racks for now ! Quote Link to comment Share on other sites More sharing options...
crooked Posted September 26, 2011 Author Share Posted September 26, 2011 Running heaps better, found that the generator has been rebuilt twice because of a charging fault, once in 1999 and once in 2009, I hope its just my battery that needs a charge... Not holding charge, runs alright now though, fixed the horn, started to panel, getting there... More sanding tonight, then probably get it primed properly... Cant get the fu#*ing hub caps off... !!!!!! sh!t god damn!!! Anyone with a visor? i want Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 14, 2011 Share Posted November 14, 2011 Alright, I took over this car on saturday after a nice drive back from hamilton with 3 others as 'cop spotters'. Made it in one piece and no fines. Brake stopped working a couple of times and discovered a brake cylinder leaking quite badly so have taken that off and into a brake shop to get it fixed. Have also sanded back some visible bog and primed the panels except roof. Popped the rocker cover off and adjusted the valve clearances, runs a million times better now and cold starting works mint!! Greased all the grease nipples and oiled what needs oiling so should be good to go once the brake cylinders back then off to see what she fails for a WOF. Need to wire up top brake light and fix speedo one day this week and probably give the ignition a good refresh as shit looks old. Should make a good daily while I spend more time on the Prince. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted November 18, 2011 Share Posted November 18, 2011 Quick update, My brake cylinder is done so should get that sorted this weekend. $63 bucks inc gst from Race Brakes on New North Road. Fixed sticking right rear brake, just needed to back the adjustment off a tiny bit. Tighten up front left wheel bearing so no more sloppy wheel, Fixed high stop light and sanded more dodgy bits/primed. Am going to repaint the whole car its factory sky blue color which should look nice, probably do it this weekend/next week. So now for wof hopefully just need to replace the front tires as one has some strange cut going the whole way around the outer edge and weld a couple of patch panels in the front left inner wheel well, rangi up the bonnet so it dont look so shit and fix the bonnet open button inside the cabin as i think there must be a break in the cable somewhere as it does nothing. Fingers crossed shes all ready to roll by next weekend. Then its only a couple of minor problems to fix, fuel seems to leak a little from the carb where the throttle shaft thingie (no idea what it call) is attached. Hopefully not a major. Also need a stereo and a peice of door rubber for the drivers door so it stops sounding like a wind tunnel. Then its drive drive drive time. Any suggestions? Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted February 2, 2012 Share Posted February 2, 2012 Still havent gotten around to giving it a WOF but should be very soon, am still waiting to get my tires in. Have tidied it all up. Sp far everything works only the tires I can see are shit. Has pollen all over the car in the photos but the matt black actually looks a bit nicer when washed Let me know what you think. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted February 3, 2012 Share Posted February 3, 2012 FIRST WOF SINCE 2009!!! Time to drive the shit out of it. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted February 29, 2012 Share Posted February 29, 2012 Little update. Car has been running mint, done about 700miles in it without a hassle till one day at the mad butcher. Starter motor decided to crap out, took that out and a rebuilt one was going to be $280 bucks. fuck that, got a second one off trademe for $20 just waiting for it to arrive. most likely within the next couple of weeks will be blocking it all back to get a nice base and fix any nasties then a mate of mine is going to spray it properly in a booth, a nice glossy black. and im after a tape deck, old school looking. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 3, 2013 Share Posted January 3, 2013 This cheeky little Minx is now mine. Purchased from Dave today. Had an issue where it would die with no throttle applied. When I took it for a test-drive, we noticed that the ignition coil had also been getting unusually hot. When it came time to collect the car, I took a new coil with me. Installing it has stopped the stalling issue. Also installed the chrome headlight surround rings. No immediate plans as such, but I have a list of things that will eventually be done. Some more eventual than others. -Replace generator with alternator from modern (pick-a-part) japanese motor -Replace window seals and door rubbers -Replace engine mounts -Ditch current radio and speakers and install another properly -Remove rust (though the car is surprisingly solid in this area) -Rebuild carburettor and possibly engine. Will start with the easiest first. -Install windscreen washer bottle and pump (until then, I'll just squirt from a drinkbottle out the window) -Possibly install beauty rings (although I'm growing fond of the current look) -Panel and paint Have only driven it twice, but it keeps up with (and occasionally beats) modern traffic. Also has some sweet pin-up art on the bootlid, courtesy of Mrs123456789. 1 Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 3, 2013 Share Posted January 3, 2013 Picture from it's last outing, at the Auckland charity BBQ cruise 1 Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 3, 2013 Share Posted January 3, 2013 Another from the same outing Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 5, 2013 Share Posted January 5, 2013 What is that lump of cast iron sitting out front? You guessed it. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 8, 2013 Share Posted January 8, 2013 The pedestrian friendly, ergonomic bonnet opening device was past it's prime. Plus I was worried that my new battery and other fancy bits would be stolen in no time. So I went from this: To this: Made one good bonnet release out of the two broken ones that it came with. So now I have a fantastically functional ONNET release handle. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 26, 2013 Share Posted January 26, 2013 Cylinder head has been reconditioned. Basically, it had burnt an exhaust valve on cylinder #3 aaaaages ago. Sadly, It had then been driven on three cylinders for aaaaaages. I bought it, drove it home and removed the cylinder head. Head gasket was blown and cylinder number three had cracked its exhaust valve seat. Sooooo, after cleaning and disassembling the head, it was put back together with a new exhaust valve above cylinder #3 and a new corresponding valve seat. The compression has been upped by planing the head. Replaced the frost plug too. Should run smoothly and rather swiftly now. Incase you're wondering which shade of orange that is: That's right. It's misspelt Chevrolet orange. Here are the existing valves: And here is the new exhaust valve: Managed to track the valve down through Bowden Engine Parts, from Tauranga. Gaskets were very cheap. So I bought the conversion gasket set too. The engine leaks from all over the place, so I'll pull it out completely and replace all of the gaskets and paint it. 'Chevey' orange for sure. I just know that this is going to snowball into me painting the engine bay while the motor is out... Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted March 4, 2013 Share Posted March 4, 2013 All back together and running again. New engine mounts. Inspired by the humble scotchbrite dishwashing sponge. Head cleaned and ready for final placement: With the valve clearances set it fired into life. So far so good. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted March 4, 2013 Share Posted March 4, 2013 Quickly painted the bonnet. It's in the garage drying now. Will put the after photos up eventually. With a paltry thirty something dollars for another three months of registration paid, I'm looking forward to chugging along to the Albany Meet this weekend. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted March 13, 2013 Share Posted March 13, 2013 Rebuilt the carburettor the day before the Albany meet. Removed a few foreign particles that had caused blockages and cleaned out the fuel pump and filter. Looks better now that the exterior is all one colour. Ran like a dream. Cruised at 55-60mph and went up the Harbour Bridge in top gear with no sign of slowing. I actually had to back off. Quote Link to comment Share on other sites More sharing options...
