R100 Posted August 30, 2011 Share Posted August 30, 2011 Currently wiring up an RB25DET. Its a Variable valve timeing version. How important is it to connect up the variable valve timing ? Will it make much of a difference to the power ? Everything else about the engine/turbo is standard. Basically i do not have loom that came with the engine and are adapting a RB20DET loom. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted August 31, 2011 Share Posted August 31, 2011 Id wire it in. Its only a 1/2 wire plug, depends really on your ecu your using, if your using 20det loom i dont think this plugs into the newer style rb25det ecu so if that the case youll need ro run some form of external driver, not worth it. Quote Link to comment Share on other sites More sharing options...
2JZKP Posted August 31, 2011 Share Posted August 31, 2011 if it was me id run it, but as requiemk said if using a 20det loom it wont plug into your 25det computer, id try source a 25det vvt loom man will be the easiest option Quote Link to comment Share on other sites More sharing options...
R100 Posted September 1, 2011 Author Share Posted September 1, 2011 Can i run the RB20DET ECU and loom on the RB25DET engine ? I have been ringing around wreckers to find the correct RB25DT loom but it hasnt been easy. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted September 2, 2011 Share Posted September 2, 2011 Yer you can but was a bit of fiddling around with it, cant remember specifics.The injector and coil pack plugs are different, but that was a minor issue compared to other things that werent right. There should be no difference to a s2 rb25de engine loom and the rb25det loom. finding an ecu may be tricky. Quote Link to comment Share on other sites More sharing options...
