Headlight relay help
shavenYak
Dear Olde School,
I want to run relays for my headlights to take some strain off the shitty wiring and existing relay/switches in the combination switch.
I have a pair of "headlight relays" that I took out of a Saab, but the wiring diagram is doing my head in / I'm stupid. Can someone please assist? I can't find my camera so here is a little drawing of what's on the side of the relay:
What should I connect everything to? Thanks!
Yours shavenly,
The Yak.
your not stupid, that's just an really weird wiring diagram.
looks like 56a and 56b are hi beam and dip beam
's' probably switches between these two options
31 is ground
and i think 30 is power
and 86 is the headlight on switch
i would get a 2nd opinion before wiring up like this for peace of mind too
s = low beam high beam switch, earth already mentioned, 30 12v feed, 86 = head lights on switch. 56a to low beam relay, 56b front lamp filament monitor and daytime driving lights? cunt of a setup. go spend 12 bucks and get a normal relay.
whats a front lamp filament monitor? do these outputs not simply switch between two circuits? ie high and low?
its some sort of ammeter which can tell if one headlight is drawing more load than the other, and sends that to the dice module. dice = Dashboard Integrated Central Electronics. its a saab thing :lol:
