phtmbl Posted July 11, 2011 Share Posted July 11, 2011 I am trying to find new front and rear windscreen rubbers for my GTO. I can not get them from mitisi as they no longer make/stok them for this car, does anyone know where to get after market ones or if any from another mitsi will fit? I am also tring to get the rubbers that run up the quater window to seal between the door glass and quater window. Quote Link to comment Share on other sites More sharing options...
s15 Posted July 11, 2011 Share Posted July 11, 2011 Try Novus, they should have something to retro fit. Quote Link to comment Share on other sites More sharing options...
felixx Posted July 11, 2011 Share Posted July 11, 2011 basis might be able to help, they have lots of different rubbers. just find the one that has the same cross section. Quote Link to comment Share on other sites More sharing options...
phtmbl Posted July 12, 2011 Author Share Posted July 12, 2011 Sorry should of put this in the first post, I have tried all the usual places like Novus, Smith and Smith and rare spares they can not provide. I can get a roll from Basis but due to the shape of the corners on the gto screen it is not advised to make one. Quote Link to comment Share on other sites More sharing options...
dwlee Posted July 12, 2011 Share Posted July 12, 2011 The front screen rubber I got was for a GC galant that I had to shorten the sides, but a part from that it fitted perfectly top and bottom. I got it from ebay seller phil's rotary's http://stores.ebay.com.au/MAZDA-PHILS-R ... CTS-RUBBER I don't know if the rear window rubber for a GC/GD will fit or can be made to fit a GTO, but looking at photos they look a lot bigger than a GTO. Probably the best place to get dimensions is on Sigma-Galant forum. They could also measure the length of the window divider seal as there is replacement available for the GC couple at rarespares http://www.rarespares.net.au/rarespares ... ct=RGDSL5A note different left and right. A good site to find front windscreen dimension is http://www.windscreens.co.nz/ but sadly they don't have info on the rear. I hope that helps. Dave PS the only place I've been able to get a boot rubber from with the correct dimensions is at Scotts old auto rubber http://www.scottsoldautorubber.com.au Quote Link to comment Share on other sites More sharing options...
