mekemelorry Posted June 1, 2011 Share Posted June 1, 2011 Hi Anyone have any info on what the setting is /with or without vacuum line connected , as cant find anything on here and google only turned up some odd info on a supra forum, Thanks Quote Link to comment Share on other sites More sharing options...
fulloc Posted June 1, 2011 Share Posted June 1, 2011 -10 at idle i think? mine is and that seems to be what most toyotas ive come across run. different setting for limp mode though Quote Link to comment Share on other sites More sharing options...
87MKII Posted September 28, 2012 Share Posted September 28, 2012 -10 at idle i think? mine is and that seems to be what most toyotas ive come across run. different setting for limp mode though How do you know when its in limp mode? Im having timing related issues with my 1geu. Ive got intake backfire and the timing is set at over 20* Quote Link to comment Share on other sites More sharing options...
fulloc Posted October 8, 2012 Share Posted October 8, 2012 bridge e1 and te1 with a paperclip or wire (in the diagnostics plug) idle should noticibly drop. you can then chuck the timing light on and move the dizzy round to the desired point Quote Link to comment Share on other sites More sharing options...
