My name is Russell Posted May 29, 2011 Share Posted May 29, 2011 Super long shot but anyone have a pipe bender that takes the new main hoop pipe size of 44.5x2.5mm for my cage builder to quickly borrow? Trying to make sure cage is done in time for 25th June Manfield event. And scetch for munu to look at. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted May 29, 2011 Share Posted May 29, 2011 That's a worry! Is he able to get a larger die for his bender? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 29, 2011 Author Share Posted May 29, 2011 Yeah the parts on the way but delaying build by two weeks or so thought i would try my luck. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted May 30, 2011 Share Posted May 30, 2011 Looks the same as my cage builders bender. He wont lend it but would be able to do your cage in a couple of days . How much are you paying for the one in the scort? Get your guy to ring ProParts in Palmy, they might have a former in stock if you're lucky. It's also very unlikely that you'll have homologation back before the 25th of June. They've been taking a couple of months for normal ones and a month or so for "rush" homologations... So you could be best to roll without for June? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 30, 2011 Author Share Posted May 30, 2011 Ga really! he seemed to think the turn around was only 3 days when i asked him about the paperwork processing time. Are you allowed to run an un homologated cage in your event? Quote was for around 2K but sounds like going through to strut towers for 8 point cage might cost little more now. frostmotorsport.co.nz So far he has done the footplates but said if the delay is an issue i can drop of somewere else. Will pass on info about ProParts in Palmy to him cheers owl. Quote Link to comment Share on other sites More sharing options...
