eskie77 Posted April 10, 2011 Share Posted April 10, 2011 hey so ive got a 77 panel van with mild cam.ive lost the valve settings specs that i got with the cam, so should i just set them alittle more open than standard settings on both the inlet and exhaust ?? ive got them set at the moment standard which probably is causing her to be under powered.i know it depends on the lift of the cam and such but yeah just curious... thanks for your help in advance Quote Link to comment Share on other sites More sharing options...
Valiant Posted April 11, 2011 Share Posted April 11, 2011 Standard tappet setting should be fine. check them again just to be sure they are spot on. Give the car a decent tune, often it is a lot of minor things all together causing problems. Quote Link to comment Share on other sites More sharing options...
