N/A to Turbo EFI questions.
abikenut29
you're better off sticking to the ECI system. Just find Starion inlet and turbo manifolds, you're going to need to either change to an EFI fuel tank, or fit an external surge tank and lift pump setup.
No point going to megasquirt or LINK ecu, it's still a crappy throttle-body injection system to begin with. If you were to use an aftermarket ECU, you may as well go multi-point injection while you're at it.
