Guest SHGWAG Posted April 10, 2013 Share Posted April 10, 2013 My only real other option would be to get a full stainless system made. But that'll cost $$$$$$$$$ Link to comment Share on other sites More sharing options...
Guest durty Posted April 10, 2013 Share Posted April 10, 2013 stuff some steel wool behind the silencer? Link to comment Share on other sites More sharing options...
Guest Rookie Posted April 10, 2013 Share Posted April 10, 2013 How is that going to make it quieter? Just do what thriller said, but keep the muffler on the back you want to use, and fill it with steelo, it works a charm. Link to comment Share on other sites More sharing options...
Guest durty Posted April 10, 2013 Share Posted April 10, 2013 Alternatively 3 Link to comment Share on other sites More sharing options...
Guest Rookie Posted April 10, 2013 Share Posted April 10, 2013 Sold! Link to comment Share on other sites More sharing options...
Guest SHGWAG Posted April 10, 2013 Share Posted April 10, 2013 Won't the steelo just blow out as soon as I hit boost? Or do you mean: Keep silencer Fill with steelo behind silencer. Get Cert / Wof Remove silencer. Hit boost Blow out steelo? Link to comment Share on other sites More sharing options...
Guest SHGWAG Posted April 10, 2013 Share Posted April 10, 2013 I thought supertraps were illegal now? Link to comment Share on other sites More sharing options...
Guest Rookie Posted April 10, 2013 Share Posted April 10, 2013 Na you need tools to change them so they are legit. Also exactly what you wrote ^ Link to comment Share on other sites More sharing options...
Guest durty Posted April 10, 2013 Share Posted April 10, 2013 Won't the steelo just blow out as soon as I hit boost? Or do you mean: Keep silencer Fill with steelo behind silencer. Get Cert / Wof Remove silencer. Hit boost Blow out steelo? Exactly this I thought supertraps were illegal now? Even if they are illegal now ya gotta pay the cost to be the boss Link to comment Share on other sites More sharing options...
Guest Beaver Posted April 10, 2013 Share Posted April 10, 2013 because there are no other rotarys in the world I can see how you have no idea how to make it quiet enough.. 2 Link to comment Share on other sites More sharing options...
Guest Rookie Posted April 10, 2013 Share Posted April 10, 2013 That's dumb Beav. 2 Link to comment Share on other sites More sharing options...
Guest Toucan Posted April 10, 2013 Share Posted April 10, 2013 Just decrease pipe diameter/add mufflers/add loops. Weren't you saying it has too much power as it is? Restrict it all and make it quieter. Single stone, two birds Link to comment Share on other sites More sharing options...
Guest SHGWAG Posted April 10, 2013 Share Posted April 10, 2013 There's no more room for mufflers / loops due to the large rear subframe / where the exhaust has to run. And Andrew, most people do it the dodgy way as described above, but I'm wanting to avoid that. Reducing the exhaust size will reduce the power / increase back pressure. Link to comment Share on other sites More sharing options...
Guest slacker.cam Posted April 10, 2013 Share Posted April 10, 2013 This is just a stupid hoop to jump through. Once you get the rubber stamp it's irrelevant so just do whatever it takes that's easy to undo. 2 Link to comment Share on other sites More sharing options...
Guest LOW'N'SLOW Posted April 10, 2013 Share Posted April 10, 2013 This thread needs more pix 1 Link to comment Share on other sites More sharing options...
Guest SHGWAG Posted April 10, 2013 Share Posted April 10, 2013 Old photos from earlier this year, nothing much has changed since then apart from a few small things.... you get the idea. Link to comment Share on other sites More sharing options...
Guest SHGWAG Posted April 10, 2013 Share Posted April 10, 2013 So Friday I'm getting a new centre section of the exhaust with a 2.5inch dia muffler in there rather than the 3inch. This should solve the problem temporarily. I will be retaining the 3 inch section to bolt back in once this thing is legal. Link to comment Share on other sites More sharing options...
Guest flyingbrick Posted April 10, 2013 Share Posted April 10, 2013 That miata is of the hook! Dammit I'm so white. Put a restrictive plate in between exhaust flanges. With like 1" hole In it Link to comment Share on other sites More sharing options...
Guest thegreatestben Posted April 10, 2013 Share Posted April 10, 2013 Haha you need one of these. I had one but I threw it out sorry... 1 Link to comment Share on other sites More sharing options...
Guest Mk1Daniel Posted April 10, 2013 Share Posted April 10, 2013 ^ Looks kinda like my one haha, exept more holes. Got me an exhaust cert though Only JUST got upto the revs it needed to. had to add to Adreniline R reso's aswell. Link to comment Share on other sites More sharing options...
