danger Posted June 15, 2009 Share Posted June 15, 2009 Putting a series 4 RX7 internally regulated alternator onto my series 1. Have removed the external regulator and found this diagram on ausrotary.com. Can anyone just tell me if this diagram makes sense before I do it? I have teh charge indicator and ignition wires sorted. Quote Link to comment Share on other sites More sharing options...
danger Posted June 15, 2009 Author Share Posted June 15, 2009 Someone answer or i'll napalm your suburb Quote Link to comment Share on other sites More sharing options...
Mick Doohan Posted June 15, 2009 Share Posted June 15, 2009 so you have the main output wire ... straght to batter via a fuse .. 60/80 amp or something a charge light .. the heads off to the dash and a exciter/energiser wire ? .. normally conects to switched ignition take a piccy ?? sorrz ... drawing is pooos Quote Link to comment Share on other sites More sharing options...
forced Posted June 15, 2009 Share Posted June 15, 2009 It will probably work with 30 connected to 86 and the relay thrown out. Steve Quote Link to comment Share on other sites More sharing options...
Mick Doohan Posted June 15, 2009 Share Posted June 15, 2009 It will probably work with 30 connected to 86 and the relay thrown out.Steve so its self energising then ? Quote Link to comment Share on other sites More sharing options...
danger Posted June 15, 2009 Author Share Posted June 15, 2009 Well this is what I need to know. I'm guessing the charge indicator needs the relay etc due to it using the tacho as a gauge on a series 1 rx7 till the ignitions turned on. I've rewired the car so was gonna run the output from the alternator back to the battery via the starter motor power feed and have the black igniton feed wire coming from the cabin which is what i'm guessing your calling the energiser wire. Does the circut for the charge indicator look like it makes sense? ie diodes round right way etc? I just dont trust a drawing off the internet. Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 15, 2009 Share Posted June 15, 2009 the charge indication light needs a relay(or switch of some kind) to stop it being on whenever the car is off?? Quote Link to comment Share on other sites More sharing options...
danger Posted June 17, 2009 Author Share Posted June 17, 2009 Well fuck it, built it as its drawn. Used 12g wire for the 4mm squared stuff. Is that acceptable or bang? Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 18, 2009 Share Posted June 18, 2009 12 gauge is 3.3mm^2?? im gonna set up my no charge light like this unless someone tells me why i cant Quote Link to comment Share on other sites More sharing options...
