bubblegoose Posted October 3, 2009 Author Share Posted October 3, 2009 oh look those ugly massive indicators have been removed a revised steering lock all thanks too..... OMG its tinyfied. butt welded tube then those reinforcing plates are plug welded on too and its almost straight Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 9, 2009 Author Share Posted October 9, 2009 RE:sump wont last five minutes now holds about 400mls more oil, has 25mm wide skid rails folded over on the bottom to be 4mm thick. a front skin of 1mm steel (no oil behind it) then the main oil pan is remade from 3mm thick sheet and has a low profile sump plug i here by challenge anything to penetrate my oil pan and yes i deliberately left it whorey looking to scare hedgehogs out the way Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 23, 2009 Author Share Posted October 23, 2009 spendy......very spendy but i did get to do this there all together at last poor pic but now in the 3rd revision, they have been brace top and bottom and have mounts fitted for a more modern approach at sway bar links and a new lock stop some go faster bits, nology leads and a holley blue pump stripped cleaned and then...... left, need to re drill the mains to 1.8 and lift the needles up a clip (i hate that job i always loose the tiny springs) just need a new cross member and i can start throwing it all together Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted October 27, 2009 Author Share Posted October 27, 2009 thought id flip the ring gear over to the fresh side, had the dryer on in the garage (mega humid) which made a thick layer of ice over my frozen flywheel. was so hard to not lick it there finally all in place with the brake lines all fitted etc SHIT! where did that bit get too, time for a treasure hunt found it was in the container of bolts for the old front struts r1 carby school time in the top of the slide you will see this lil white tag carfully pull it out with needle nose pliers, BE CARFULL there is a stupid little spring behind it (dont be tempted to push it out with the needle they bend too easy) this is your buried treasure, the stock position for the circlip is the middle groove i dropped my clip down one notch, dont forget to replace the little plastic spacer if you do your car will run like a dead dog easyest way to replace it all is to fit the needle into its hole the lift it back up and hold it steady while the replace the steel washer, spring and lock tab keep pressure on the spring while you push it back and lock it into place then check the needle is still free (few mm movement) and has spring tension repeat 4 times Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 6, 2009 Author Share Posted November 6, 2009 so i required some bits to finish of my engine mainly these (was missing some bolts aswell but meh) yes i work on my car in pitch blackness brought an entire engine (for $22) to take off any bits i needed then scrap all the alloy for max profit apparently had blown head gasket due to blocked radiator, umm nah i think it got hot cuz of this cambelt wasnt too old either seems it was driven on for a while in said condition and wait.. they let me have a magic pen and some drugs Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2009 Author Share Posted November 20, 2009 not done alot really center console is all cut out for my shizzle, just need to get the textured paint on it now one more coat of paint then clear coat it, also getting the car reprayed this yellow nah just kidding its the same yellow as the engine bay but with more flash on it car will be fully resprayed in ppg base and clear *cough*for free*cough* to match my engine bay paint as i likes it more than the current lellow Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 5, 2009 Author Share Posted December 5, 2009 perfect with half decent lock and fuel tank back in place some other stuff has happened but i was too busy doing it to take pictures Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 11, 2009 Author Share Posted December 11, 2009 new fancy trigger wheel and intake trumpets total cost $40 crap picture but my engine and box are fitted (currently on grahams engine mounts) can now sort out my plumbing have smashed out the dent in the rear panel will fill that full of green cheeze later need to get my seats sorted and want to do my headers again and make them look complicated Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 16, 2009 Author Share Posted December 16, 2009 wheels taken off and tyres removed.........hmmm bit of a strugle to get it up though Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 18, 2009 Author Share Posted December 18, 2009 one more try Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 20, 2009 Author Share Posted December 20, 2009 i hear that the current fashion is to have mangled steel pipes in your engine bay so i thought id be a sheep and follow on a few gaps to sort out and then i can take the support straps off and tidy it all up there all 27 +/-1 inches long too Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 27, 2009 Author Share Posted December 27, 2009 moved a brake line and made a heat shield, have discovered the worlds best brake line brackets. will move the rear line when i can be arsed got a new dash with guage holes in it, not sure iff ill use it or not. couldn't make my mind up then i did that and they looks the bizzle have a ghetto flow bench in the makings aswell Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 30, 2009 Author Share Posted December 30, 2009 clay was too cold/hard for me to be arsed getting ti perfect right now but crammed almost that much shit into the port with no loss of flow, quite happy with that so a added more and reduced flow by about 7-8% probably what ill leave it as sucks fingers in quiet easily too Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 2, 2010 Author Share Posted January 2, 2010 das nockenwelle, kelfords Vs. stock lumpier than genital warts Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 4, 2010 Author Share Posted January 4, 2010 exhaust ports knife edged and castings smoothed (worst casting ive seen), valve seats smoothed in and combustion chamber de-shrouded Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 19, 2010 Author Share Posted January 19, 2010 engine mount jigsaw some black flek and some purdy gizmos, megajolt is behind that rubber bung settled on those cam gears Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 20, 2010 Author Share Posted January 20, 2010 crank up teh welder brewski just need some pretty bolts with a 12.6mm od Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 23, 2010 Author Share Posted January 23, 2010 so thats all done, thank fuck and this picture is for dan/d.p.n.s its a 'dirty great intercooler' Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 24, 2010 Author Share Posted January 24, 2010 low res for the winz Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 28, 2010 Author Share Posted January 28, 2010 dummyed up oil cooler boso spec for lol's god it looked gay. its too big to go anywhere else so its either bosofail or buy a smaller one also marked these out with electrical tape because im too jew to buy a new pen will be brushed with 3000 pads for silky smoothness Quote Link to comment Share on other sites More sharing options...
