Scrubb Posted June 17, 2007 Share Posted June 17, 2007 My uncle has got my lancer fixed for me but it still needs the clutch and carb done. He was talking about I needed to know the 'settings' for it so he can fix it.. he used to know them but forgot. I think he's gonna rebuild it or something I'm not sure, I didnt even know they had settings So what I need to know is what carb do I have? I have a 1980 Lancer EX GSL with a 4G32 belt driven engine so does anyone know what carb is on these and the settings I need? At least if I know what carb I have I can let him know and go from there.. Any help will be appreciated! Quote Link to comment Share on other sites More sharing options...
Ogre Posted June 17, 2007 Share Posted June 17, 2007 is a solex downdraft, 28/32, may be able to get you jet sizes, but not sure what you mean by "settings" cant really change much but mixture Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 17, 2007 Share Posted June 17, 2007 yuh only external adjustment will pretty much be idle mixture. chuck a dgav weber on there ftw Quote Link to comment Share on other sites More sharing options...
Scrubb Posted June 17, 2007 Author Share Posted June 17, 2007 Theres nothing internally? I think he wants to pull the whole lot apart I'm not sure he's adimant theres more info I need... Found this: http://www.manuals.co.nz/?page=shop/flypage&product_id=8716&keyword=solex&searchby=title&offset=0&fs=1&CLSN_728=118206275272842e17510c1c5c171519 Will this have the info I need? Quote Link to comment Share on other sites More sharing options...
Scrubb Posted June 17, 2007 Author Share Posted June 17, 2007 Ok, I called him up and he told me he wants to know Choke/Throttle butterfly setup measurements... Quote Link to comment Share on other sites More sharing options...
fuel Posted June 17, 2007 Share Posted June 17, 2007 I don't think it will be a Solex, most likely an Aisan downdraft carb. Quote Link to comment Share on other sites More sharing options...
Scrubb Posted June 17, 2007 Author Share Posted June 17, 2007 Cant find any info on Aisan ones.. Does any one have any useful info on these Mikuni/Solex/Aisan carbs? Quote Link to comment Share on other sites More sharing options...
Scrubb Posted July 1, 2007 Author Share Posted July 1, 2007 Got the carb pulled apart... its full of shit.. no wonder the car dont go! It says "AISAN" on the side and also "iso" and it had a tag under one of the bolts which reads: "C28LD". Does anyone have any info on these at all? Quote Link to comment Share on other sites More sharing options...
fuel Posted July 1, 2007 Share Posted July 1, 2007 I knew it would be an Aisan carb! I think the 28 refers to the primary bore size which would be 28mm. Secondary is probably 32mm. I'm pretty sure they are the same carbs used on most other post 80ish mitsis but with different jets to suit different engine capacities. Quote Link to comment Share on other sites More sharing options...
Ogre Posted July 2, 2007 Share Posted July 2, 2007 yeah, pretty much all the mitsis use the same carb from bout 1980 to about 87 both FWD and RWD, and all the engines.Just jetted different for them. Quote Link to comment Share on other sites More sharing options...
Scrubb Posted July 2, 2007 Author Share Posted July 2, 2007 Yeah, when my bro went to supercheap to get the carb kit they didnt have Lancer EX on their computer but all the Lancers with 4G32's had the same carb so I guess its the right one.. Just wish I could find some info on it.. Quote Link to comment Share on other sites More sharing options...
