Popular Post sheepers Posted November 28, 2021 Author Popular Post Share Posted November 28, 2021 the injectors i got for it are those ones with a cap on the top and a cap on the bottom to adapt them to different types of fuel rail and different lengths. dont get them. i fought the fucking o rings in the caps leaking for days. if the injector has even a tiny bit of angle to it as you ty and install it they leak. fucking piles of shit. managed to ruin a base seal and i dint have any spares so i had to improvise. i had a larger and thicker ones from a nissan so i set about making them smaller on the od and thinner. 2021-11-21_04-17-12 by sheepers, on Flickr 2021-11-21_04-17-04 by sheepers, on Flickr 2021-11-21_04-16-48 by sheepers, on Flickr 2021-11-21_04-16-33 by sheepers, on Flickr 2021-11-21_04-16-26 by sheepers, on Flickr with that done the only thing left to do was relocate the oil cooler and fit some fans to it. the only fans i could find that were small enough but still waterproof came from the states, they weren't expensive but they took a bit to get here. the oil cooler is now mounted on the side of the chassis rail between the engine and the rail, behind the steering rack. ive been driving it around with a thermocouple in the oil cooler just keeping an eye on the temps. its pretty good and drops fairly quickly as soon as your driving as there's a bit of air flow. so anyway i made a bracket type setup and mounted the fans onto the oil cooler. all i need to do now is wire in the relay and they should work. im back on the dyno on Tuesday so yea, lets see what happens. 2021-11-28_05-10-37 by sheepers, on Flickr 2021-11-28_05-10-31 by sheepers, on Flickr 2021-11-28_05-10-22 by sheepers, on Flickr 2021-11-28_05-10-14 by sheepers, on Flickr 25 Quote Link to comment Share on other sites More sharing options...
Popular Post sheepers Posted November 30, 2021 Author Popular Post Share Posted November 30, 2021 back on the dyno today and all was well. the car took yet another beating and was fine. no fuel issues, no anything issues which was a relief tbh. made 460 KW again on slightly less boost but call it the same. fuck, like it matters at this point, its undrivable at that level anyway so what difference does it make. oil stayed cool and the oil cooler fans seem to work good too which is great. i do need to replace the heat shielding on the exhaust that goes under the floor. that last lot got oil all over it so i removed it and man can you feel the heat coming up through the floor now.... 2021-11-30_10-20-12 by sheepers, on Flickr 27 2 Quote Link to comment Share on other sites More sharing options...
Popular Post sheepers Posted November 30, 2021 Author Popular Post Share Posted November 30, 2021 Oh yea shit I forgot to tell you why everything got covered in oil. So right after I moved the oil cooler I took it for a drive round the block to check shit out. As I pulled away from the kerb I heard a weird sound and it continued as I got to the end of the road and round the corner. I was coasting along watching the gauges and trying to figure out what they noise was when the oil light came on. I shut er down quick smart and got out to have a look. It had inexplicably pushed one of the oil houses off the push lock fitting (that it had been on with no issue for about 3 years) and sprayed all 5 litres of oil all over the entire engine bay. And all over the road. Richie just happened to turn up at the right time and with his help, and the help of Nick the sparky (who, despite being forewarned of the ground being covered in oil stood straight in it and fell over) we pushed it back up the hill and into the garage. There is still oil on everything despite emptying can after can of degreaser all over it. 21 13 Quote Link to comment Share on other sites More sharing options...
Popular Post sheepers Posted December 12, 2021 Author Popular Post Share Posted December 12, 2021 yea right so i took this out for a good 5 hour long back road thrash. i dunno how to convey to you just how good this car is at hooning back roads, its fucking EPIC. fuck its amazing. i lose track of what this car is capable of when im just driving it to work and back every day, yea its fast and pulls like a fucking space rocket but thats only half the story. i suppose the best way to put it is that its got brakes, grip and stability to match every one of the 460kws the engine is making. and as a plus its now got better low end torque so you can just leave it in a higher gear and it will still come out of a corner like its been fired from a gun. im definitely in love with it all over again. 2021-12-11_03-04-09 by sheepers, on Flickr 54 4 Quote Link to comment Share on other sites More sharing options...
Popular Post sheepers Posted November 4, 2023 Author Popular Post Share Posted November 4, 2023 26 2 Quote Link to comment Share on other sites More sharing options...
Popular Post sheepers Posted November 11, 2023 Author Popular Post Share Posted November 11, 2023 Had to do some rust repairs for wof. Didn't realise how bad it had got, both sills behind the doors needed work. Is a common rust area for celicas, side window dumps shit down the quarter and it's sort of double skinned at the bottom. Anywho, drivers side needed a whole new inner and outer sill made and passenger just had two small holes so I welded them up. Side note, I thought I had already been in to the sill in the past but it turns out it was all original. So it had lasted 47 years which isn't to bad. I fucked up the clear on the drivers side and got some runs in it but you can't really see it. Also I did a pretty good job of flicking in the new colour over the top of the old. She's pretty hard to fade metallics but this time I did alright. 57 Quote Link to comment Share on other sites More sharing options...
