LOW'N'SLOW's Mk1 escort (. )( .)
  • Replies 83
New Wheels (13X7 Performance Superlites with 185/60 Directionals fitted), lowering blockes put in (Cheers gazza), rust removed from rear left guard and replaced with new steel (Cheers Nick / Mk1mad), new wood grain stearing wheel and boss kit fittted, added a boot poper and shaved over wholes yesterday. (Rice cannon came with the car shouldn't be there for muct longer)
Spent weekend working on car, pumped the rear guards with the Fender Reforming Tool, ended up using it as more of a dolly to hammer against.
Removed petrol tank and welded up the reverse light holes, badge wholes and trim wholes. Took front struts out and dropped the spring off to be compressed. Painted front sway bar and fixed a little rust on one of the guards.
Picked up some Austin Princess 4 Pot Brake Calipers and vented Ford Capri Discs on TM :D should help her stop better when the 2L conversion is done.
Also picked up a Central Locking Kit that hopefully i will be able to get to work then wire up to an alarm and shave all the door locks.
and got a battery protector that is supposed to cut of the power suply to your electronics if your battery is running to close to flat.
Uni study break so got a little time to work on the car :D orthough its very weather dependant at the moment.
Have welded up a few wholes;
New disks Vs Old
New AP Calipers and old
Installed the central locking on all 4 doors so once iv made sure thats working reliably with the alarm will shave the drivers lock also and hook up to the alarm just need to come up with a contingancy plan for if the battery goes flat any ideas?
Welded up the broken drivers seat rough as but will hopefully pass a WOF and do for now untill i can get new seats certed along with everything else.
Got a new shinney wheel and boss kit :D
replaced the mk2 boot poper swith with one i picked up from J Car ... its a key spring loaded critter that seems to do the trick.
Fixed my window winders with new handles (they had broken off)
guards fixed on now so here are some pics.
Marking out and cutting of the front guard alowing room for the edge to be roled out.
marking and cutting of the rear guard which wasnt as simple as the front as it had double skins.
What bog?
The double skins on the rear guard were both folded outwards
then welded back together with the slits also later welded and tack welds also along the edge.
The front guard was also folded out at 90 degrees proior to doig this the panel was flimzy as hell but once this was done it was quite rigid.
Test fit (front)
(Front)
(Front)
(Rear)
should of fitted all the wheels and taken a photo but couldnt be assed
Nicked Gaz's mk2 struts and stearing rack in order to fit the 2.8i capri vented disks
By lownslowz, shot with DSC-W1 at 2007-07-03
Put all the new seals in and made up all the brake lines
By lownslowz, shot with DSC-W1 at 2007-07-04
Had to make my own brake pad retainers with clips.
All ready to be bolted up.
2 X New tie rod ends
Picked up a 2L sierra of TM with 205 block and 5spped man so getting that on sat from Napier ways with Gaz and grabing another CA for him and Another CA for pies...good thing its a wagon! Also picked up some quarrted bumpers of uncleJake, cheers man :D
Gaz workshop is going to be free in two weeks so i intend to paint the esky in there. Looking at painting her a colour similar to gunmetal grey what you fellas think? hoping to have the car done for summer fingers crossed!
Gaz needed to take his wheels of to get them cleaned up so he borrowed my mags so i took a few pics;
Next page :D
