spacie
681f block is the predecessor to the 711m, found in Mk.2 cortinas and the early Mk.1's. This *could* be a legendary 'L' block - the ones that were modded for the original 1558 twincam, although it's more likely to have been out of a 1600E or similar. You need to check the deck height for that.
Just call me a sad bastard :D:D
full code is 681F 6015DA
what is it???
681F 6015
The ‘L’ version of this block was the original fitment in MKII L/Cs and obviously takes the 3020E type b6 bolt L/C crank. Round main caps. Most will bore to 85mm if they have a low ‘T’ number.
as this early crossflow unit used in 1600Es and 1600 GTs carries the same number as the MK II L/C but is easily
http://www.lotus-cortina.com/library/block/blocks.htm
haha so in other words its a 1600?
Almost certainly. These blocks were all the same bore, and varying cranks were used to change the capacity. If it's *not* a 1600, then it could be worth lots! Is is a 4 or 6 bolt crank?
Whatever, it's the best of the (usual) early 60's kent blocks, but not as good as a 711M.
havent pulled it apart yet so cant tell ya, will rip her apart sometime this month
