Guest LOW_EX Posted December 26, 2006 Share Posted December 26, 2006 is there any type of struts that will fit a 81 ex lancerr that are shorter? Quote Link to comment Share on other sites More sharing options...
Blueex Posted December 26, 2006 Share Posted December 26, 2006 The best/cheapest way is to carefully dismantle them & have the shafts shortened or buy inserts & have them shortened. Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 2, 2007 Share Posted January 2, 2007 insert from a colt lancer is shorter, but its just easier to the get the ones in there made shorter.Not hard or expencive.inserts outa the 20valve sprinters fit and are shorter ive been told, but meh, cheaper to just shorten some EX ones. Quote Link to comment Share on other sites More sharing options...
rxtoy Posted January 2, 2007 Share Posted January 2, 2007 i've tried 20 valve struts (ae92 from memory) and they don't fit without a shit load of messing around and custom stuff, easier to shorten stock ones. cheers Matt Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 4, 2007 Share Posted January 4, 2007 i was just talking about the inserts.I wouldnt even bother with those even Quote Link to comment Share on other sites More sharing options...
rxtoy Posted January 4, 2007 Share Posted January 4, 2007 sorry, i did just mean inserts. ended up ditching them and going back to shortened stock inserts. made for a heaps better ride once working right. cheers Matt Quote Link to comment Share on other sites More sharing options...
Ogre Posted January 8, 2007 Share Posted January 8, 2007 yeah for sure, i would try finding some GSR struts as they have a 55mm internal strut area as opposed to the stock ones witch are 45mm, sigma etc may be 55mm, im not sure.Just means that you can put way better inserts in, and they stronger etc i guess Quote Link to comment Share on other sites More sharing options...
