excort Posted February 2, 2006 Share Posted February 2, 2006 hey guys i have converted my escort to manual and was wondering if anyone could tell me where abouts i have to run the clutch cable threw the fire wall i have a hole allready but its to high any help would be apreciated cheers Quote Link to comment Share on other sites More sharing options...
davidian Posted February 2, 2006 Share Posted February 2, 2006 right behind the clutch pedal :~ Quote Link to comment Share on other sites More sharing options...
excort Posted February 3, 2006 Author Share Posted February 3, 2006 that does not seem to work :S.... it pulls the plastic bit out of the top of the pedal ? Quote Link to comment Share on other sites More sharing options...
Guest kris Posted February 3, 2006 Share Posted February 3, 2006 that does not seem to work :S.... it pulls the plastic bit out of the top of the pedal ? WTF? Angled piece of tubing, it goes in there. If you have it in there and the plastic pulls out, then I think you have assembled your pedal incorrectly. Hang on. Was auto. You need that angled bit of pipe. Do you have it there? You can tell it's a Friday - I sound like a f**k'n drongo. Quote Link to comment Share on other sites More sharing options...
Eskorted Posted February 3, 2006 Share Posted February 3, 2006 sup make sure u drill the hole directly inline with the pedal. not to high but not to low! if its to low the cable will bend on the pedal and snap it... (ive been through 3 cables) also get a 2 in long pipe wide enough so the plastic bit fits just into it. cut it on a angle and angle it up. weld her up and all systems go. make sure u tighten up the adjusting nuts good cause they have a habbit of rattling loose. but yea its Very important that the cable does not touch the pedal when fully pressed down. PS i kno what ur talking about the plastic bit coming out. mine done the same. one of the lil clips on the side broke off, so now i have 6 cable ties holding it down it works mint! just put one across the fron one on the back and 4 in a X over it Quote Link to comment Share on other sites More sharing options...
excort Posted February 3, 2006 Author Share Posted February 3, 2006 oh cheers for that man well i worked it out today i drilled the hole abit further down and i put t he cable like threw the bottom of the plastic bit so it dont touch the pedal so it shouldnt snap i dnt t hink tho i think ill do what you siad about the angled peace of metal eventually cheers guys Quote Link to comment Share on other sites More sharing options...
