Guest seriour Posted December 26, 2005 Share Posted December 26, 2005 Hi i have a 78 lancer GLS with a belt drive 4g32. is it possible to put a chain drive 4g32 short block into it with out any mods?? how can i tell if my engine is a short or long block too?? Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 26, 2005 Share Posted December 26, 2005 Generally the terms Short and Long block aren't referring to the actual physical size of the block, more the amount of ancillaries etc it has. A short block is generally the block itself, crankshaft, pistons, rods etc. but not the head and a long block includes the head and depending who is selling it, the intake/exh alternator, blah blah as well Quote Link to comment Share on other sites More sharing options...
Guest seriour Posted December 26, 2005 Share Posted December 26, 2005 cheers thats kinda what i thought. so this short chain drive block should be able to bolt to my cross member and use my old engine mounts etc etc?? Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 27, 2005 Share Posted December 27, 2005 I'm not 100% cause i'm not big on Mitsi's but one would think that it would be a matter of bolting the chain drive cam procket onto instead of the belt drive sprocket and wallah (caution: wallah does not include timing which would possibly be thrown entirely out of whack) Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 27, 2005 Share Posted December 27, 2005 I'm not 100% cause i'm not big on Mitsi's but one would think that it would be a matter of bolting the chain drive cam procket onto instead of the belt drive sprocket and wallah (caution: wallah does not include timing which would possibly be thrown entirely out of whack) that wouldnt work. timing chains need lubrication...... I think what he's wanting to do is put a complete chain drive 4g32 in place of a belt drive 4g32. i'm not big on mitsis either but i would imagine they'd almost abe a bolt in, althogh there's always something top trip you up. fuel = resident mitsi encyclopedia, he'll know. although i'd stick with the belt drive on if possible. more likely than not it's a newwer generation than the chain drive. or stick a belt 4g63 in there like alot of guys on here have done Quote Link to comment Share on other sites More sharing options...
Guest redseven Posted December 27, 2005 Share Posted December 27, 2005 As far as I know there the same, ie should bolt in no probs i think the heads slightly different to allow for belt/chain. http://www.trademe.co.nz/Trade-Me-Motor ... 978920.htm see how the chain runs through the head? im sure the belt runs outside the head like a sohc 4g63. Quote Link to comment Share on other sites More sharing options...
TygerTung Posted December 28, 2005 Share Posted December 28, 2005 Would bolt straight in Quote Link to comment Share on other sites More sharing options...
Speedyrr Posted December 30, 2005 Share Posted December 30, 2005 I've got a number of old 72-73 16L colts, my original has a chain 4g32, the another has had the beltdrive 4g32 dropped in later and bolt straight up. A couple of my 1850's colt have had the same transplant, 4g51 chain drive taken out and a 4g32 belt drive put in instead, straight bolt up. All of these are rwd, and most of the colt stuff was interchangable as is a lot of the mitsi stuff. Quote Link to comment Share on other sites More sharing options...
Guest seriour Posted December 30, 2005 Share Posted December 30, 2005 phat az good to know. i might just rebuild a belt drive one tho cos that chain drive engine is quite pricy on trademe...see link above Quote Link to comment Share on other sites More sharing options...
