Guest Scheme Posted October 8, 2005 Share Posted October 8, 2005 My mates 180b starts and idles fine, but as soon as you apply some throttle it craps out, whats the most likely problem? its just running the standard 1.8l carby motor.. Quote Link to comment Share on other sites More sharing options...
rxtoy Posted October 9, 2005 Share Posted October 9, 2005 not a lot of info there but first thing i'd check is fuel filter and have a quick look in the carb, see if you can see anything blocking up the jets. has he run the gas tank empty lately??? could have sucked up some shit from the bottom of the tank or something like that. cheers Matt Quote Link to comment Share on other sites More sharing options...
Guest orange_mini Posted October 9, 2005 Share Posted October 9, 2005 check the float bowls on the carb or the fuel pump yeah Quote Link to comment Share on other sites More sharing options...
lowlancer Posted October 9, 2005 Share Posted October 9, 2005 Vacuum lines? Would not even idle in that case though... Quote Link to comment Share on other sites More sharing options...
