Guest lotus legend Posted September 26, 2005 Share Posted September 26, 2005 Well my KE70 corolla as featured in the whole '4 reverse gears' fiasco has recently lost virtually all braking ability. First time they go straight to the floor and dont do an awful lot, after that it doent get alot better. They have been bled and theres plenty of fluid, any ideas? of course when we put the diff in the right way a rubbery thing and a spring were left over frome the back brakes... Quote Link to comment Share on other sites More sharing options...
Defcon Posted September 26, 2005 Share Posted September 26, 2005 Does it have a Drum assembly on the rear end? If so thats most likey your problem. I would take a stab and say that is the handbrake spring. With out that the shoes may be completely out of adjustment. Hence you push you foot to the floor and the shoe has a long distance to travel before it contacts with the drum. Reinstall it and adjust the shoes till there just about contacting the drum and giv it a try. Def' Quote Link to comment Share on other sites More sharing options...
Guest lotus legend Posted September 26, 2005 Share Posted September 26, 2005 yea will have a look tomorrow, the only problem is the spring looked a bit broken so it woodnt hook up at 1 end. i dunno Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 26, 2005 Share Posted September 26, 2005 its only a padock basher rite? clamp the rear brake line with some vise grips and then see if it gets any better.. then tell us more.. Quote Link to comment Share on other sites More sharing options...
Guest lotus legend Posted September 26, 2005 Share Posted September 26, 2005 pretty high performance paddock basher none the less, that 4k pumping 60hp and it feels all of that. hows clamping the line going to help? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 27, 2005 Share Posted September 27, 2005 rear cyclinders often leak. just general fault finding, see if its because of the rears or founts/master cyclinder. Quote Link to comment Share on other sites More sharing options...
