L0WMK2 Posted August 25, 2005 Share Posted August 25, 2005 driving to meet and flicked on my lights and they didnt turn on, pulled over and rear tail light was busted and got another from repco and still not going any help? Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted August 25, 2005 Share Posted August 25, 2005 do your parking lights work? do the rears work when your lights are ment to be on? what do u mean by rear light was busted? 1 bulb blown or? Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted August 25, 2005 Author Share Posted August 25, 2005 light bulb was smashed, high beams still work Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted August 26, 2005 Share Posted August 26, 2005 Smashed? was the lens broken too? Maybe the bulb socket is stuffed cos someone hit it with something. Check if 12V is getting to the bulb holder. Also make sure it's earthing properly. I think you said all the rear lights were not working last nite. If so I'd check fuses and earth wire. Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted August 26, 2005 Author Share Posted August 26, 2005 Smashed? was the lens broken too? Maybe the bulb socket is stuffed cos someone hit it with something. Check if 12V is getting to the bulb holder. Also make sure it's earthing properly. I think you said all the rear lights were not working last nite. If so I'd check fuses and earth wire. just the bulb got smashed nothing else, yeh wiring is so shit in my car have to look into it Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted August 26, 2005 Share Posted August 26, 2005 so is it a series circuit? so if one thing goes so does everything else? fukin brits lol Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted August 26, 2005 Author Share Posted August 26, 2005 so is it a series circuit? so if one thing goes so does everything else? fukin brits lol think so Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted August 26, 2005 Share Posted August 26, 2005 bugger. Quote Link to comment Share on other sites More sharing options...
Guest kris Posted August 26, 2005 Share Posted August 26, 2005 so is it a series circuit? so if one thing goes so does everything else? fukin brits lol think so No Way. Bulbs all in parallel, earthed at bulbs (each lamp cluster has its own, shared by all bulbs (brake, tail and ind). Power feed to bulbs via switch. Even brit electrics aren't that crazy. Feed to switch? Switch? Get a multimeter on it. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted August 26, 2005 Share Posted August 26, 2005 mk2s are gettin pretty old bro check the switch. mine stuffed out so did my hi/lo switch. was goin to fix em but rewired whole car up to modern standards with a fuse box and relays etc. also deloomed engine bay its sweet now Quote Link to comment Share on other sites More sharing options...
mkcortina Posted August 26, 2005 Share Posted August 26, 2005 I had something like this a few years back. i still havent fixed it properly but i will when i re loomk the car. so if i have this correct. you have park lights. when you turn you main beam on it you have no lights. when you turn on the high beam they come on. if this is so i have found that the earth connection between the headlights and body was o/c, i dont know where. So what i did was pulled out 1 head light found the earth pin connected a new wire bteween earth and the pin. that fixed it for me and it has been fine for abt 3 years now. hope this helps Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted August 26, 2005 Share Posted August 26, 2005 He fixed it last nite before he came out. dunno how though.. Quote Link to comment Share on other sites More sharing options...
