drftnmaz Posted August 15, 2005 Share Posted August 15, 2005 i have to take my diff apart and was wondering if there balanced from factory? ie if i take the bit with the spiders off the crown wheel do i need to mark it and put it back in the same place? i've never bothered taking a diff apart i've always just changed the whole head. Quote Link to comment Share on other sites More sharing options...
Guest kris Posted August 15, 2005 Share Posted August 15, 2005 No, but it wouldn't hurt. You do need to adjust the shims properly to make sure the crown and pinion mesh properly and then set the preload correctly. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted August 15, 2005 Author Share Posted August 15, 2005 hmmm how would i go about that???? how mcuh pre-load you guys recon? Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted August 16, 2005 Share Posted August 16, 2005 to set it properly you will need some engineers 'blue' and some preload shims. are you putting the same components back together or making 1 diff from 2? Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted August 16, 2005 Author Share Posted August 16, 2005 same components back in, i spose its not like i have any spare shims anyway blue ink i do have tho Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted August 17, 2005 Share Posted August 17, 2005 basically you will just be bolting it back together then. just wipe the'blue' on the crownwheel and the pinion teeth and rotate slowly . as the two mesh it should wipe the blue off evenly in the middle of the teeth. if its wiping off 1 side or the other more you will need to shim it in or out by adding or removing shim washers. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted August 17, 2005 Author Share Posted August 17, 2005 mint, thanks for that Quote Link to comment Share on other sites More sharing options...
Guest kris Posted August 17, 2005 Share Posted August 17, 2005 For preload you will need a new crush washer - then it's book settings. Otherwise really carefully measure the torque it took to take the pinion bolt off, and then do it up exactly the same amount. Quote Link to comment Share on other sites More sharing options...
