Defcon Posted August 5, 2005 Share Posted August 5, 2005 The blocks leaking oil from where the temp sender was snapped off. Tryed to use an easy out to get it out, but it snaped off! Tryed to drill it out, but hit the hardend steel from the easy-out and drilled the block instead. Ive tryed covering the fuck out of it with metal putty(knead it ect) but it still manages to leak out. Any one got any ideas, I thought about progressivly tac welding it, but with an iron block theres a chance it might crack. Def' Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted August 5, 2005 Share Posted August 5, 2005 Start with a 1mm tungsten tipped drill and work your way up had to do this on a water pump once. Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 5, 2005 Author Share Posted August 5, 2005 Yeah that would have been the idea, but the problem now is that the thread has been drilled from my efforts, so pulling it out, would just lead to a bigger hole. I need to cover the whole area some how, block it off, so no oil comes out, kinda hard at 100 psi o/p. Def' Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted August 5, 2005 Share Posted August 5, 2005 Drill another hole once you get it out and re-tapp a larger dia thread the original hole is 3/8" I think so drill and tapp a 12mm or 1/2" then put a plug or a reducer for the sender. You should probably remove and strip the engine for this due to the drillings and shit Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 6, 2005 Author Share Posted August 6, 2005 Cheers dude,yeah shoulda thought of that, am not keen to strip her as i just rebuilt it, but i guess its right on the dowels, and i do not want metal filings in the oil! Perhaps time to invest in some vlt pistons while im at it. Cheers, def' Quote Link to comment Share on other sites More sharing options...
isnowi Posted August 6, 2005 Share Posted August 6, 2005 For a quick fix seal, try JB weld, its as dear as poison but it is awesome.. Quote Link to comment Share on other sites More sharing options...
Defcon Posted August 7, 2005 Author Share Posted August 7, 2005 Cheers, ill give that a go first. Where abouts do u get it/ Thanks, def' Quote Link to comment Share on other sites More sharing options...
