pulley how do you undo it?
WildPlumDx
the engine is in the car and yes the crankshaft and i like the idea of the 1st gear thing! was gonna do it but wasnt sure if it was good for the car thanks! i'll do that oooh also my pulleys cracked put i measured a 4k pulley and its the same diameter this is for my 4g54 mitsy 2.6L ute engine reakon she'll be sweet with a 4k pulley !?
figure out what way the pully turns and then use a power bar on the pully so the bar is close to a chassis rail in the right direction then disconnect the coil and if u really want the plugs,
then line the bar up and give the ign a real quick flick over and this should crak the bolt loose.
