Guest Ronald_loulan Posted January 25, 2005 Share Posted January 25, 2005 PLs tell me how does Pushrod works... Quote Link to comment Share on other sites More sharing options...
davidian Posted January 25, 2005 Share Posted January 25, 2005 do a search man the cam is in the block oposed to having a "overhead cam", etc etc Quote Link to comment Share on other sites More sharing options...
RT Posted January 26, 2005 Share Posted January 26, 2005 the cam in the block pushes rods that open and close the valves in the head.. put simply Quote Link to comment Share on other sites More sharing options...
Guest Ronald_loulan Posted January 26, 2005 Share Posted January 26, 2005 Any pic bout the pushrod...?? I still dun understand.... Quote Link to comment Share on other sites More sharing options...
davidian Posted January 26, 2005 Share Posted January 26, 2005 thats probably cause you need to learn Engrish Quote Link to comment Share on other sites More sharing options...
RT Posted January 26, 2005 Share Posted January 26, 2005 Ok, this is a cross section of a Hemi V8 but you can get the idea of what a push rod does. It's a rod that opens and closes the valve as opposed to a OHC engine which has a cam and follower setup working the valves. Quote Link to comment Share on other sites More sharing options...
esky boi Posted January 26, 2005 Share Posted January 26, 2005 Well, he has a lot to learn if he doesn't know how a pushrod engine works Quote Link to comment Share on other sites More sharing options...
2DR73XA Posted January 26, 2005 Share Posted January 26, 2005 pushrods = a link between the lobs from the cams direct to the roller rockers, when the lob on the cam comes around it lifts the pushrod up, which transfers the momentum to the roller rocker which then opens the valve into the cylinder......... dude, go have a read of a basic automotive engineering book, that will help heaps.......if you think pushrods are hard to understand...... wait to you get to dizzys and vacuum advanced timing.....!!! Quote Link to comment Share on other sites More sharing options...
Guest Ronald_loulan Posted January 26, 2005 Share Posted January 26, 2005 Good info.... Thank very very much... Quote Link to comment Share on other sites More sharing options...
trunk-rattlin Posted January 27, 2005 Share Posted January 27, 2005 just by looking at his location. maybe he does need to learn engrish. Quote Link to comment Share on other sites More sharing options...
Guest chevysrocknroll Posted February 2, 2005 Share Posted February 2, 2005 engine builder report. you mist the part about the lifters. the cam the lifter then the pushrod Quote Link to comment Share on other sites More sharing options...
2DR73XA Posted February 2, 2005 Share Posted February 2, 2005 yes i know......... but i ddint have all day to go into lifters and solid lifters, mechanical lifters....etc... and anti pump lifters and roller cams and sh1t+........... you could always go into it now if you want........ feel free Quote Link to comment Share on other sites More sharing options...
