Guest kornstar Posted November 16, 2004 Share Posted November 16, 2004 i have the chance to grab a 5 speed gear box for the kingy, does any one no whether a VK gearbox would fit in the HQ sedan?? it was last in a one tonner. i know it will bolt stright up to the engine but will it fit allright where the box sits and will i have to change the drive shaft? Cheers. Quote Link to comment Share on other sites More sharing options...
Toucan Posted November 17, 2004 Share Posted November 17, 2004 If you can just take some measurements to get an idea. I think your the only one on here with a kingswood so not too sure if anyone else will know, sux huh Quote Link to comment Share on other sites More sharing options...
davidian Posted November 17, 2004 Share Posted November 17, 2004 nah ,im shure there was another dude with a kingy.. but like the man said.. measure the lenght of the box and compare them both, then have a look at the mounts on the gearbox and the mount holes and compare. also have a look at both rear ends of the boxes to see if the spleens match. if you cant use the same d/shaft, its always easy enough to get a auto one and a manual one and make a hybrid.. Quote Link to comment Share on other sites More sharing options...
