lowlancer Posted July 14, 2004 Share Posted July 14, 2004 My Celeste's auto is making bad sounds, as if the g/box is bangin against the housing or something...Any ideas? It only happens under heavy-ish acceleration, and when I go over potholes. It also has a tendency to stall off the line, but I may have fixed that with air filter today. Any help appreciated to put my mind at rest Quote Link to comment Share on other sites More sharing options...
BigDave Posted July 14, 2004 Share Posted July 14, 2004 Not sure on your set up but possibly the gearbox cross member type support under the car?? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted July 16, 2004 Author Share Posted July 16, 2004 Right got myself a haynes manual.... That prick is gonna be out and a 5 speed in can i put the twin carb manifold set up from the GSR strait on mine? Will I need to modify anything? Quote Link to comment Share on other sites More sharing options...
Linesy Posted August 6, 2004 Share Posted August 6, 2004 Hey Lowlancer, What engine is in the Celeste? I assume a 4g32 (1600cc).Your GSR manifold might fit, I think there are slight differences between the chain drive and belt drive engines. Basically the celeste is a hatchback Lancer so most bits change over. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 8, 2004 Share Posted August 8, 2004 that knocking could more than likely be the c-v joint knocking. Quote Link to comment Share on other sites More sharing options...
Gas Monkey Posted August 8, 2004 Share Posted August 8, 2004 that knocking could more than likely be the c-v joint knocking. The Celeste is rear wheel drive if i'm not mistaken Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 11, 2004 Author Share Posted August 11, 2004 Yeah you got it, 4G32, so it won't be too much of a job? Sweet. And as for the knocking, its gotten way worse, as in it is always happening. It's right under the brake pedal.... I've had a look and tried to wiggle stuff, but its all stiff as a catholic priest at a choirboy convention. And I got stuff alll money...Ah the joys of old cars Quote Link to comment Share on other sites More sharing options...
