Everything posted by eskie77
thanks heaps for the replies,ill do some research on those sites and make a decision
that would be awsome if you could scan that for me man,thanks heaps.Already have extractors and a decent carb.I have the head off and thought i may aswell do some work to it.
im trying hard to do research on google on porting and polishing lol ,hasnt been so sucessful as of yet.. i guess if i muck it up too much i can get another head of tard me.Not really wanting to spend mega bucks on it like that haha but i bet it was awsome.
hey just after some advice/tips on a bit of d.i.y polishing and porting of an escort 1600 head. Is it worth doing myself or should i just bite the bullet and pay for it to be done.Advice of what to do and what NOT to do would be awsome .thanks in advance:)
balanced driveshaft ? and is your universals ok on the drivshafts ?
a knee capping is in order !
hey thanks for the info,ill be doing pretty much all of it myself..im a qualified mechanic.is most of it wiring that is the problem,how much cutting of the body is involved as duno if i wanna cut up me eskie lol
hey,has anyone on here put a 4age into a escort.if so how much is involved and aprox how much is spent making this change over thanks just brain storming what to do to my road weapon to make it a bit faster without modifying a whole lot.if you have done this mod ,have you had to do the rear brakes to disc also. thanks
so you sayng i should give this one a miss lol ,its gone above my price range now anyways as i dunno if it will work or not lol
hey,been on trademe and have seen this electronic dizzy for 40bucks,not sure how hard it is going to be too hook into my 1600 escort or even if it will work... thoughts...ideas my escort friends lol any help appricated cheers oh auction number 411126974
what was plan b man ?>
mmm ive already got spacers in,might have to double them up,good idea bout drilling the mounts out to make the engine lift up.mmm the options..
hey thanks,sounds like im going to have to do some experimenting...
hey been doing a bit of work on my escort over the weekend and noticed the engine sump sits on the steering rack.The engine mounts are spaced out with steel but still not enough to clear the sump.Can you get longer engine mounts for to clear the sump and are they 1600 ones or 1300 ones or what lol.The engine im running is a 1600 any help greatly appreciated
are you talking about the rocker cover leaking or the front timing cover leaking.I replaced the rocker cover gasket as could smell oil burning .The smell dissapeared when i did it but now has returned and i am thinking these seals you are talking about are the culprit !
whoops sorry gaz
edit: oh and what kinda struts are u running now if you dont mind me asking ?
yeah i think im heading towards cutting them thanks
im in palmerston north ,oh yeah who sells them ?
ah i wanna do it on the cheap.
heya,im going to lower my escort with lowering blocks at the backs,whats the best way to lower the front to match the back evenly. Cut springs so still captive or heat the springs.Been reading a fair bit bout shortening shocks to keep the springs captive on here. ideas escort modifiers lol
hey man ,is it a auto choke or a cable operated choke ?if it an auto choke make sure its all adjusted properly.I have a 1600 escort and had major troubles adjusting the chokes till i got it right now it starts first pop took ages too get it right.
hey so ive got a 77 panel van with mild cam.ive lost the valve settings specs that i got with the cam, so should i just set them alittle more open than standard settings on both the inlet and exhaust ?? ive got them set at the moment standard which probably is causing her to be under powered.i know it depends on the lift of the cam and such but yeah just curious... thanks for your help in advance
thanks heaps for all your help ill have a look at the threads
yeah i probably shouldnt of put minor mods,i want to put a more modern engine in it and get more power and a five speed box.Im a mechanic by trade so do all the work myself except for the cert ....
