StuT
Everything posted by StuT
Hi all Question about putting in an overflow tank on to my Capri. Does the tank need to be higher than the radiator or set low okay since should work on pressure? No real room for up high would be half way down radiator on side of engine bay. Thanks in advance
So situation is my 3 litre essex is getting tired and needs rebuilding. I do have 2 other ford v6 engines but not sure what they out of or size Hoping the are compatible so can build a good one with my heads and cam etc Dipstick on front not side Any help appreciated thanks in advance
Most additives say they help stale fuel and water in lines etc. As for carb yes pull down ideal but looking to buy new 38 soon as current 40 webber on last legs
Hi, anyone used a fuel system additive in a carb engine? Just wondering on any benefits of flushing out stuff. Or any sucess with octane boosters? Running old essex v6 with 96 and lead additive. Cheers
Outlaw brakes are meant to fit under 13", been looking myself for my capri . Cheaper set up also.
Wow thanks for that didn't know the laser option. I have the v6 mark 1 hubs which have a bigger deeper hat shape. Same as oz cortina. Not same as the most capri's escorts
Did quick mock up with calipers on. All seemed good just need to go get calipers serviced and 2 to 1 piping made. Thanks
Thanks Rookie, did you need to do anything else to get them. To work right?
Quick quiz, will my 13 inch ford wheels fit over a Austin Princess 4 pot brake upgrade? Changing calipers only
Bummer just found thread. Will keep watching and bring my crapi out next time. Good to see a strong local crew. Nice pics of nice cars
Thanks ofnsiv Packing do you mean bushings on end? Will investigate these options first
Yes still leaf with lowering block Not sure what involved in coiling it. Watt kit about $600 from uk or $1450 from chch!
Q. Has anyone fitted one of those atlas watts linkage kits to there escort? Looking to do to my capri to tighten up rear end. Seems best solution, bushes etc all good
Manage to find some replacement rotors thanks to help from bnt. Don' t ask for v6 capri rotors ( everyone lists them wrong) order v6 cortina ones. Problem solved.
Offset totally different alsoapprox 100mm from rotor to flange where bolts onto hub. As opposed to about 20mm. Most os forum say give up and get other struts
Hey big mat I dwould be keen to see what you end up with. Doesn't see robe anything on market to help at moment. Who doing it for you!
Thanks Nigel have been surfing all night and seems can't swap over hubs, onlt complete struts and hubs. Will try Repco or BNT tomorrow to see if can get new rotors. Need "big hat" version. Worst case try and tidy current ones up. Nothing on Tardme now. S
Hi All i have V6 Mark 1 capri and need new front rotors. Problem is they odd style "hat type" Bolts thread from outside into the tread on rotor as opposed to thoer style Escort (some capri like 2.8's) bolts go thru from back of rotor threading into hub. Much more common and easier to get better rotors Question is will an escort hub go straight onto crapi V6 axle so i can use better rotors. thanks in advance Stu
Hey all, Got a 3 litre v6 with type 5 (internal linkage) gear box. Problem is drops out of 2nd when changing down from 3rd. Goes great when rev'd and shift from 1st to 2nd. Anyone had experience rebuild one of these? I do have a Celica W50 (unknown condition) with proper bell housing to fit one day. How hard and $ to rebuild this? Still need to sort clutch and pressure plate (size?) Opinions welcome, porbably looking for the cheapest easiest fix first. About to get car re cert'd for other mods also Cheers Stu
Do mk1 capri diff heads fit into escort diff housings?
StuT replied to wickmyster's topic in Tech Talk
looks like a Atlas diff, which if so won't fit into escort diff. try getting the whole lot and fit in. I think it will be minimally wider overall. Good luck -
Just went thru same thing on my old thing with no experience 1st thing i di was a $10 test light from repco hooked the yellow up to light switch power red to cig lighter blk to any earth wire Good luck, Jaycar normally pretty cheap for speakers!
Hi All Im at the point where i have to tell the painter the colour to stick on. I know the look Im going for just trying to make it all work. Question is which is the strighter, cleaner, white in the old school ford range? Choices seem to be Polar white, Diamond white (bit yellow i think), Ultra white....? others looking for a very crisp white to highlight the black(satin) blackouts. Could go for a modern colour Winter white on new focus/mondeos etc. Sounds stupid but want to use a ford colour! was gold and not going there Any help much appreciated
Thanks all Will go with a W50, waiting on a reply from Steel Surgeons Dellow conversions look pretty professional and got back with a price. Heading over to Oz next month may end with that if not hear back from SS. Slowly making progress on project.
I'm running a Essex V6 currently with a C4 slush box and wanting to make manualize. Sierra 5speed doesn't bolt straight on and not ideal for the torque i've been told. All suggestions lead to a W?? Toyota 5 speed. Question is how hard and what to look for? Sorry for the ignorance, like the old school rides just not a oldschool mechanic! (not a mechanic at all for that matter )
