so engine wise it was an expensive engine rebuild, it needed new rods, crank, pistons, plus all the usual junk, the engine was already .0020" over so was sitting at 1293 cc.
The decision was made to go to .0060" to take it our to 1330cc. the "race" head i already had got sat away in the corner ready for the bottom end to be rebuilt. the bottom end was balanced up including a metro clutch setup modded to take a heavier clutch diaphram.
The resulted in a clutch plat that was almost too thick to properly release. and full engagement about 2cm from the floor. As you can imagine a bitey clutch soon saw the end of the first set of uni's. So i upgraded to cooper s uni's. which also did not last too long.
The next step was to go to a metro diff (sick of changing Uni's and i had callopsed diff output bearing) and metro C.Vs. not long after this my flash head with oversize valves decided it didn't want the valves to stay in the head and promptly tore a head off the stem.
This of course led to a very sad looking piston.
from there the valve spring pressures were measured and they were running WAY too much spring pressure. So the head got all new oversized valves and the spring pressures set up properly. Whilst in there the ports got a bit of a teflon coat to keep things slipperey.
For the next 2 years the car developed an appetite for starter motors, crank seals, distributors, alternators, carbs etc. So I kept replacing these bits and used the car as a weekend fun car. I did the civic dizzy replacement which works nicely, but then the gearbox idler case (where the starter bolts on) decided to split open a bit, since then the car has been parked up on blocks in the corner of my garage. I start it now and then to keep it healthy.
I'm probably just making this project thread up to try and get enthused about the little beast and get back to tearing up back-roads on sunday afternoons.
