fuzzb8
New Members
Everything posted by fuzzb8
  1. hey guys and girls im currently tryign to get my 1980 rwd mazda 626 back on the road ive bleed the brakes up but they still not working fully pads and calipers are good no leaks or anythign i have noticed when you pump them up the let the pedal go the reservoir is bubbling on release any ideas thanks
  2. if you sign up and read the walkthru on aus rota it will tell you what wire to cut and join up by the auto shifter peice of piss really. hardest thing for me to find was the pedal box
  3. USE the auto xmember and weld tags liek on the aussierota link it i followed the whole set up off that aussie rota website its a good walk thru hardest part was getting a mate to do the wiring for me(which is piss easy) i used a manual ecu. you need manual pedal box driveshaft starter flywheel or lightened flywheel on your counter weight works fine diff ratios are different but thats not a major
  4. yeah dry ice is the Key to getting it off
  5. when putting a lsd into a b1600 housing i know you have to shorten one axles jsut cant rememebr which oen if this helps you
