Posts posted by HighLUX
Outside hoist wrapped in Denso tape would do the trick
I have a contact in Tauranga who does olde HIFI repairs.
He might be interested in having a look
Should get one of my bikes going for this but meh will prolly just buy something to thrash for the weekend
This is mighty tempting
- 5
Didnt spot the NOS D21 tail lights?
Not the best turnout of vendors this year. Think the threat of the weather put alot off but it was actually pleasant for once, not raining or freezing cold
Or theres these rails you can buy with indents and threaded bosses so you slide the boss to where you wanna strap something down then screw on an eye bolt and ratchet things down.
Some way to add those to the insides of the wellside?
Fill with water block up the holes and use a waterblaster like hydroforming?
Keen for a spot in the olds to go buy some junk
Or I think Mondeo is another good option for 2 speed fan that pump lots of air and should be easy PaP fodder
$1.04/L for LPG with a rockgas card makes something like this a good option for cheap motoring
https://www.trademe.co.nz/a/motors/cars/toyota/camry/listing/3629222110
On 09/06/2022 at 13:01, NickJ said:
Fancy pants rental car I had could read speed signs and adjusted the speed warnings to suit, do any radars have that ability?
Fancy hilux at work has this but it gets confused by two 10kph signs right next to each other and says your good for 110kph
Bike work is quite satisfying
Small amounts of time gain lots of progress
Bash plate plus custom sump that is wide and high? Mod pickup to sit closer to the crank and add big wings to keep oil capacity up so you get more metal to road clearance?
Did the same with my emission spec import hiace. Got a carb off a NZDM hiace bolted straight on. Blocked off excess vac ports and ripped out all the gubbins/solenoids. Didnt worry about the dizzy. Powered up the auto choke clock spring thing and it worked perfect off the bat. Ran way nicer with better economy, would start and idle fine with the idle dropping back as it warmed up.
3 hours ago, Thphantum said:
@HighLUX you coming?
Nah in napier for training for the next week and a half
Enjoying some doggin with @TimShadboltfan27 instead
Pretty sure the coolant loop for the TB is only for stopping it freezing up in cold temps. Have you cleaned the IASC? Even abit of carbon on the barrel will get it sticking and making it idle high. They dont run a cold start injector like earlier motors so its really up to a wiring problem or a sticking IASC.
I remember @Spencer saying they needed a voltage signal after key off to reset the IASC otherwise they did the mischief your talking about or something similar
Top grille looks RX4ish?
Jailbar 323 grille should be worth $$$$$ to the dorito foamers
OOOOOO boi that noise
Eastcapescapade #6 2022 November 11th, 12th, 13th
in Upper North Island Region
Knock Knock.......
Sues there?
