Posts posted by Jeffs_Emporium
Picked up this local rebuilt second gen 1G-GTE and sold my Auckland 1GGE (thanks @Kelvin)
Popped the rear access panel off the hiace and did some measuring
-From 3Y block-bellhousing surface to radiator i have 700mm
-From 1g block to front of crank pulley i have 688mm
Quick math leaves 12mm for clearance if the 1g bellhousing is same length as the 3y one.
I'll change to NA cam covers and 1jzgte intake to help with height clearance under seats and they look more appealing, I think that will be OK!
The mid sump looks to be the right one also
New part time employer @BobbyBreeze has me fizzing to do some extra curricular custom exhaust manifold to make it all work with an updated single turbo.
It was a hard call for me to go turbo route instead of NA but the criteria for the van is to be able to hoon with all the boys and do a sick burnout so I reckon this is the best way forward.
Pretty happy with an engine that was available in 1989 going into a 1989 van!
- 16
Some boomerang Work Ewing II were sourced in a trade which I had originally traded for something else, i think @Raizer originally os freighted them to me years ago.
They were a 15x6.5 +41. Upon test fitting the fronts didn't have enough clearance to the upper arm and balljoint. I then sourced a 6.5 +17 pair from yahoo auctions and switched the centers over after Aidan at pine engineering painted them for me. This leaves me with a spare +41 5x114.3 pair for a naughty resizing for the rear in the future. I've been window shopping tyres and doing calculations on final drive plus trying to find something with a suitable load rating. 185/60/15 is legal for a 6.5 rim and will put me in the ballpark to use 3.73 or 3.9 diff ratios to get similar highway rpm as stock. 3.9 for 3y use and 3.73 for when the engine is upgraded I'm thinking. Man hilux lsd are cheap and plentiful compared to anything I've owned.
Aidan was kind enough to draw up the centre caps, plates and threads for me from a sample so I can have them cnc machined when ready to complete the wheels
- 8
Van has now changed hands and is most of its way back up to the Far North where it will be a company vehicle for a dog training business.
First and last pics for thread!
Thanks for watching!
Its no secret this van has been through a few and seemed to be the butt of a few jokes for it. A friend of a friend Alex (thanks if you are on here) made this custom item back in January along with a shortened pickup to match . I recently gave it a coat of paint and transferred the oil from the existing full level sump to check height from block. It was the same if not slightly lower (more capacity)
Heater issue ended up being a faulty tap. It would flow untill it hit a certain pressure then close off completely so I just bypassed it. The heater control unit actually also closes a flap when selecting cold temp which should help it not always blow hot.
local plastic company Cebelio cut up a scrap piece of black ABS to fill the floor shifter void, it snaps into place where the leather shifter boot would have been
As someone who has successfully entered Berghain once i felt this was a suitable plate
It also aligns with a lot of the toyota related clothing I bring in with Japan and pretty much spot on with being a 1989 van!
I wouldn't normally bother with a black plate but felt it suited the darker rear garnish, tinted windows and black tail light surrounds nicely as well as the colour of choice of clothing for true hard core techno heads
- 9
When I put this together I spent a large sum recoring the heater core, for some reason I could never get it to blow hot.I tried testing the tap to make sure it wasn't blocked and I tried checking the hoses were flowing nicely, I tried changing the orientation to make sure I wasn't running it backwards also. I remembered that I hadn't put foam packing around the core so today I pulled the entire dash out to resolve that
Put the heater box back in and plumbed it back up and bled air out. Still not blowing hot. It blows warm when you first turn it on then cools off. So I tried changing direction on hoses, blows completely cold. Tried dicking around with the flaps and taps manually to check it was doing as its supposed to and the pipes on the core are definitely hot but some reason it won't blow hot
The floor shifter model I pinched the seat base and bucket seats from had this nice strap to hold the seat base/bonnet up from the factory but it was broken in half. I remembered a local wrecker had a couple of townace utes so went and grabbed a complete strap and fixing. My B pillar didn't have the mounting point so I fitted a rivnut to get it connected.
Better than the stick I've been using for almost 3 years
- 5
The mighty TOOLBX has now been sold to a good friend! It's another month before he takes possession to drive it from Christchurch to the far north. There are all these little jobs I never got around to that I'm now getting through to hand it over in a completed state!
Earlier in the year I had some Bspeed cam covers made in a classic fin style in a red to coordinate with the BRX wheels
Great opportunity to wear a locally designed and manufactured product!
- 8
Went back to Get electronic and they refunded me all except the $95+gst inspection fee since they were unable to fix tacho and temp. I think I'll find a suitable mechanical water temp gauge to keep an eye on things untill another cluster pops up. Tried to test if there was a signal at the dash plug but don't realllly know what I'm up to to be honest
- 17
Tacho has been working previously
dizzy is putting out a signal, im going to try lift some of the pins on the plug on back of dash tomorrow, I had some temp gauge movement pulling plug out slightly so maybe they've been flattened over time.
In some better news I managed to get both sunroof and moonroof to completely open and close. Found no rust around the opening of the bigger one surprisingly its all on the removable panel, the front one has some around the edge I'll need to drop that cartridge out. Someone's definitely been there before with nuts missing here and there
Yeah it is the factory dash. Quote was 95+ if they couldn't repair it and 395+ if they could so I'll see where I stand since it's not operational still
Got this back up and running yesterday
Still looks like a heap of shit. Seems to be holding all of its fluids. Picked up the dash cluster yesterday and plugged it back it and still no tacho or temp which is pretty gutting after a $457 bill. I'd replaced the temp sensor on engine, all three radiator hoses and thermostat for a high flow option while I was there. Will run it for a week or so and flush cooling system a few times before putting actual coolant in.
Loving the height
Put the head back on and Torqued up to 30-60-88Nm in 3 stages as per specs. Put the rocker shaft back on and located pushrods. Turned over by hand a couple times to make sure they were locked in. Rocker cover back on with new gasket. I see waterpump is on clearance at repco for $21 so I'll grab one of those. Tested the thermostat in boiling water and it barely opened so I'll definitely replace that also.
- 17
Wheels have been a bit of a headache. I actually had some 15" 5H focus racing mesh in stock but sold them 3 weeks prior to buying the hiace in a 6.5 and 7.5j
The 15" focus use a 14" centre that's even cast 14" and step lips but for some reason they went for bigger m8 hardware and less fixings 8 not 12 m6 like the 14s.
This bothers me enough that I've started buying 14s one by one.
If I end up stepping them up to 15s with 12 fasteners or not I'm not sure yet but I've bought 3 of the focus spoke and 2 of the focus mesh to play around with, all in 14" 5H
- 18
Jeff's 1989 Toyota Hiace Supercustom TC24 build
in Projects and Build Ups
I still need to get these from Taranaki to Christchurch if anyone knows a door to door service, my usual man with van won't branch out to Taranaki from the main highway
