KKtrips
Administrators
Everything posted by KKtrips
  1. In all fairness, I feel lucky that @Leon did not engrave "FUK THA POLEESE" in the notes field.
  2. Just a fluke mine was that number in the queue.
  3. Nailed it.
  4. We carry a fair few of them on file, but not all of them. (it relied on the person filling out the declaration to send it into the MoT back in the day) Does it still have live rego? If it does then send me the rego number tomorrow and I'll look to see if we have a copy on file.
  5. A man can only be as good as his tools. I had my shitty old Makita.
  6. Fitted adaptors to the wheels last night to pump out the wheels a little as the spacers didn't cut the mustard. (custom made jobbies by Znoelli in Auckland - who did a great job on them) Took a nice sunset picture parked outside work last night which was unintentionally framed but caught my eye when going through the pics just now. Getting cert inspection today (fingers crossed)
  7. Is you vehicle already certified?
  8. ^nope haha
  9. This is the infosheet for design approval, effectively you are wanting custom IFS, so will need to be assessed via the Technical Advisory Committee (TAC) https://lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2016_LVV_Custom_Independent_Front_and_Rear_Suspension_Approval_Application_Guide.pdf Background:The NZ Hobby Car Technical Manual (HCTM) requires that any custom independent front or rear suspension (IFS/IRS) assembly obtains approval from the LVVTA’s Technical Advisory Committee. This includes any situation where an original equipment (OE) IFS has been transplanted into a different vehicle and where its OE suspension arm pivot-point locations have changed to non-OE locations, or where the relocation of any geometry-critical pivot points has taken place, thereby altering the suspension systems pre-set geometry.
  10. All certs are full certs, except a wheel and tyres update and partial/full return to standard. The amount of time difference between doing a "minor paperwork update" and a full recert is not that much so you might save a little, but not a whole bunch. Keeping in mind the certifier has to check that all previously certified mods are still compliant and that there are no other obvious mods that have taken place since the last cert. FYI - plating fee is approx $200 which is what pays for the LVVTA system, the rest of the cost is the certifiers time and their costs. (a plate reprint for a partial return to standard or a wheels and tyres change is about half that)
  11. Links shouldn't be dead? I'll check now. edit - nope it's there https://lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2009_V3_Tyre_Size_to_Wheel_Size_Compatibility_Guide.pdf Will hopefully be updating that again sometime soon. (I have the wheels and tyres standard on my desk for updating)
  12. If that was modified to that extent at the time of the declaration then it would be covered by the declaration.
  13. Very little, but in service replacements only. ie: anything that could be expected to wear out. One other thing you need to remember about a declaration, it is NOT a statement of safety, all it is, is a document that confirms that a vehicle was modified at the time the declaration was issued. It says NOTHING about how safe it is or isn't.
  14. Yes, but see your certifier to get an NDT form to make sure they are NDTed to the correct standard by an appropriately qualified person. Also known as an "F008 - LVVVTA Non-destructive Test Request Form"
  15. She makes a mean carrot cake...
  16. Awesome man, who's doing the cert? Julian?
  17. In the next Moonlight Racing container. It's due in a month or so.
  18. "'notha jug Bill" or something like that.
  19. Had to take it off for the tints gee.
  20. https://www.facebook.com/KustomTinting/ He did my XE and the Prius, will get him to do the BA too, and the Commy when that is back on the road. He is mobile or you can drop it to his house, he came to work and did it the workshop there. On time and no hassle. Cost $300 for the Prius (and $350 for the XE from memory)
  21. Turd polished. Now to start preparing for Wagnats. edit - oops - somehow I deleted my previous post.
  22. Spokes rub on the outside of the mount, not the caliper. Also I've checked the studs, there is at least 10 turns. 1.5mm pitch into 5mm spacers will drop that down to 7ish turns. Alternatively I could space the caliper inboard about 3mm with a thick washer behind each mount bolt but it's not really the right way to do it. *waits for you to tell me its a legit way to fix it*
  23. Fitted wheels and tyres today. But the wheels rub marginally on the callipers on both left hand side wheels. It is literally a zig-zag paper thickness clearance. So am ordering a set of 5mm spacers and will be good to go. It'll sit a little lower after I roll it back and forth a couple of times but this is a good idea of how it will look for now.
  24. Hopefully tomorrow. Rims are Advan RG's in 16x7 and tyres I'm anticipating will be 205-55-16s so should be same rolling circumference as factory tyres, maybe a teeny tiny bit bigger. These are the new rims here.
  25. No I haven't. I shall do so when it is on the 4 poster next.
