KKtrips
Administrators
Posts posted by KKtrips
  1. 4 minutes ago, ThePog said:
    Ok sweet, the brackets can be pretty compact so won't have too much leverage on them.
    @KKtrips yes it's NA, utility vehicle. There are only 4 seats.
    I got proper reels that cost money, not the $80 repco ones, although I will check the spec tomorrow.
    You will be able to visit Julian in a week or so for a look see if you were inclined...
    No, unfortunately, he is about an hour and a half drive from my work. 2 hours from home.
    You driving it over?
    The DynaSar will be NA (probably).
    So must have
    - dual sensitive in the front outer
    - lap in the front middle
    - dual or single sensitive in the rear outer
    - lap, static, dual sensitive or single sensitive in the rear middle
    edit - sorry I thought you were asking a question about what type of belt you had to fit.
    • Thanks 2
  3. 8 hours ago, Bling said:
    You may have already tried this, but you might be able to sweet talk the LVVTA to provide you the photos / some documentation to keep in the glovebox. Worth asking anyway. KKtrips would know.
    Cannot do. Photos and paperwork is the property of NZTA. Can provide a copy of the cover page only. Which you should have anyway. Though the information on the cover page will only explain the abbreviations on the cert plate.
  4. 12 hours ago, Transom said:
    I see there being a great market in bootleg lvv discs that QR code  link to a hacked page showing sick modified car as all legal occifer...
    No different to people faking plates/declarations as they do now. Expect a trip to court wnen you get caught.
    This has been thought of and there is a mitigation in place. Not sure if it is my place to say though.
    Also people will be able to access the info without an RFID scanner. You will require 2 codes to be entered manually in place of an RFID scan. It won't be a number plate as one because they change.
  5. I would but I'm keeping it, there is something a screwy with it though, can't figure out for the life of me how the spring attaches, so off it comes and I'll stash it for servicing purposes.
  6. Just now, yoeddynz said:
    Is the struggle to brake effectively and pass the test with larger wheels purely down to the extra leverage the bigger feet have over the stock brake size - rather then it being a weight or extra speed thing that upgraded trucks like this are usually having a cert test for?
    Combination of leverage, increased weight and increased HP giving less time for the heat to disipitate between heat cycles. But I understand the extra leverage plays a massive part.
  7. FYI - potential solutions are 33x10.5 tyres on a 7"wide rim and you are also allowed to fit 33x12.5"wide tyres on an 8" wide rim. The LVVTA tyre chart says minimum 8.5" but its changed and the tyre-rim chart has not been updated yet.
    In saying that, the problem you might have with 33" tyres is hauling that bad boy up and passing the brake test. Hiluxes can fail on 33's with a 3 stop brake test, yours being a scratch build requires a 5 stop brake test and I think that you are going to have an issue passing a brake test.
  8. 2 hours ago, xsspeed said:
    What is allowable in terms of wheel repairs, more thinking for cert than wolf. 2 of my SSRs had cracks on inner barrels so have now had them welded up by TTT. Currently not ground back or anything so you can see all the welding but are wheel repairs on cert or wolf mans radar?
    LVVTA Wheels and Tyre Standard says...
    Aluminum wheels must not be repaired unless the repair is carried out in accordance with the requirements specified for wheel repair within the Land Transport Rule: Wheels and Tyres 2001 (Rule 32013), in which case it is not a modification.
    Land Transport Wheels and Tyre Rule says...
    3.2(5)     A repair to an alloy wheel must:
        (a) be compatible with the material specification of the item to be repaired; and
        (b) restore the damaged or worn wheel so that it is within safe tolerance of its original state when manufactured, as able to be demonstrated by a physical test
