cletus
Moderators
Everything posted by cletus
  1. are those coins in that last one? hah
  2. wont need crack testing, i have certed a couple of bmws with similar sort of mods to get rear camber ok for cert. as long as the welding is good then you shouldnt have any trouble
  3. if you cant find the locknut, a sharp cold chisel on the outer part and big hammer should get it off
  4. yes, if you want to be 100% sure it will pass, tig it. most struts done this way have the join under the threaded sleeve so the sleeve adds strength to the join
  5. yea. sunroof 12 slots and eagers 265 hemi jacked up in the back with the diff painted red lake pipes kerb feelers mullet stubbies singlet proper old tin can of lion red jandals
  6. heres the relevant bit on the lvvta website http://lvvta.org.nz/approvals.html#design
  7. westy- you rang me a while back about the bmw with the front end changed around? if thats the case the design approval will be for non oe front end geometry- a front suspension with changed pickup points/geometry etc has to be approved by tac. so did you take it for a cert inspection and the certifier asked you to get design approval, or did the car pass and the certifier sent the paperwork through and it got picked up then?
  8. this, needs authority card for plastic windows
  9. if it was strong enough to not flex etc then i suppose it could be used. i would be careful though, there are a lot of bolt on things for various cars that claim to "make x better/improve traction/ reduce bumpsteer etc etc" that make things actually worse. to me that looks like it would make pinion angle change worse with suspension movement as the upper links are shorter than original. i dont know very much about mustang rear suspension tuning though, you have undoubtedly done more research on the subject than i ever want to haha
  10. you would have to make something work, there must be some bit of structure for the hanger bearing to bolt to, maybe you could mount the loop off that? the loop does not have to be straight across
  11. you can get the car certed for 2 different size wheels, id have to find out if the lower price 'amendment' thing applies if you want 2 sets of rims on the plate or if it would be full price
  12. Toe-n-go! haha
  13. ^this. you need to find an old school type wheel alignment guy to do a valiant properly, they are a bit of a prick to do. both the camber/caster adjusters are on the top arm on an eccentric bolt. would pay to have a real good look at all the balljoints and bushes- especially the lower arm inner bush- every valiant ive ever owned has been worn out in most of the front end parts. they are also prone to cracks where the front upper arm foward mount is welded on to the chassis
  14. not sure how you would successfully shorten a carbon fibre driveshaft.
  15. the australian is correct
  16. yes car has to match what the cert plate says
  17. yes if it all works, correct spring rate, length is right etc, then that would be fine.
  18. driveshaft loop/s is required when if the vehicle is scratch-built if it has a modified driveshaft if you have done an engine conversion that has a significant power increase if you add a turbo or supercharger to the original engine if you modify the engine so it has a significant power increase "significant power increase"= 50% more power than OE here is the info sheet http://lvvta.org.nz/documents/infosheets/LVVTA_Info_09-2011_Drive-shaft_Safety_Loop_Requirement_Clarification.pdf
  19. clintoris was the other one haha yeah the welding is a no go unfortunately. this might help explain how it can be done //oldschool.co.nz/index.php?/topic/37800-welded-strut-how-to/
  20. also, that was my nickname at work when i was an apprentice. BLAST FROM THE PAST
  21. The welding on a strut that is a problem is when there is cast or forged bits welded to mild steel, that is the issue. the bit that you can see there- sway bar link bracket- is fine. however it looks like the hub might be welded to the strut tube, which is a no go. currently even brand name struts that are aftermarket, that have welding to cast incorporated in the design, cant be certified. http://lvvta.org.nz/documents/infosheets/LVVTA_Info_05-2012_Welded_Aftermarket_Suspension_Struts.pdf second hand struts can quite often turn into an expensive drama, especially if its an odd brand that there is no parts support for here. if i had a dollar for every time ive had a look at a car where someone had got a mean deal on some second hand leaky old "adjustyz" with play in the shock shafts and missing bumpstops and incorrect spring rates, id have enough money to buy a whole block of cheese. i guess if you have a car thats not easy to get bits for then you have to take that risk, but be prepared for the possibility to have to spend some $ on them. have had a few customers spend $400 a corner to rebuild Tein struts
  22. http://wiki.hbcosmo.com/doku.php?id=engines this may be of interest to you
  23. another option might be go back to the place that gave it a wof and talk to them, they should not have issued it a wof edit; assuming the wof is new- it is not uncommon for unscrupulous sorts to get a wof and then do engine swap then sell saying its legit
  24. For repair certs? dont know to be honest, not my area of knowing stuff. we dont have to deal with those
